Rocker arm ratio
how many of you guys drive above 5700 rpm and how often...
Adam
When .006" of valve lift occurs in relation to the crank shaft degrees could be drastically different if we could change the RR drastically.
There are plenty of intricacies that must be understood when making this change, but the difference in duration is not really one of them. You aren't changing it enough to have any significant impact on idle or low RPM power. Most of this discussion is very much "spherical chickens in a vacuum" - purely academic. The important details about valvetrain geometry and handling the increased loads are getting lost because of this.
This would only be true if the valves were directly actuated by the cam. In a pushrod engine you have rockers whose ratio can be changed.
If you said that the CAM events can only be changed by changing the cut on the cam, then it would be a true statement.
BUT, if your definition of "valve events" extends to things like "intake valve opened to .050", "intake valve opened to .200", "exhaust valve opened to .050", "exhaust valve opened to .400" -- THOSE events WOULD change with a rocker ratio change because the valve is opening and closing faster. The events on the open side at lifts above .000" happen slightly sooner (in crank degrees and actual time with a constant RPM), the events on the closing side of the cam lobes at lifts above .000" happen slightly later. (Just like a car accelerating faster and braking later.) --Just like the Performance Trends valve motion+rocker ratio chart shows.
Adam
Just to say that I run 1.6 Rockers. Have for many years. Originally installed them back when I still had stock heads and Cam. Just looking for a little more lift out of the factory L82 cam on the cheap. Truthfully it didn't seem to make any difference down low at all. Perhaps a tad bit mid range and up. But it was a inexpensive mod. Never seemed to affect idle vacuum. Never found a down side.
But certainly a lot of opinions on here.
T&D and Jesel sell all kinds of rocker arms that have ratios between 1.8 , 1.9 and 2.0 providing the cylinder heads support the geometry and many do , LS’s can run those ratios too
