Ridetech Offset Trailing Arms
Old Aug 9, 2023 | 10:43 PM
Scott Marshall's Avatar
Scott Marshall
Default Ridetech Offset Trailing Arms
Can anyone tell me if the offset trailing arms that Ridetech offers is also a 2" like the ones from Vansteel?
I called Ridetech the other day and talked with one of their guys and he could not give me a definitive answer. Rather unencouraging if I say so.
Currently running 245/60r15 on stock Rally wheels.
Planning on going with 15x10 6in backspace Torq Thrust wheels with 295/50r15 radials. In theory that should bring the inner tire wall inboard 2" while leaving my outer tire wall exactly where it was originally.
TYIA
Old Aug 9, 2023 | 11:30 PM
cagotzmann's Avatar
cagotzmann
TYIA
here is the clearance with a 18 x9.5" wheel with 4.75" backspacing.
Here is where the wheel sits on the car.
Old Aug 10, 2023 | 05:25 PM
wheresmyhorsepower's Avatar
wheresmyhorsepower
My tire hits the frame rail well before the trailing arm on my 82. An offset trailing arm wouldn't allow more backspacing because it's not the limiting factor. Are the earlier years different?
Old Aug 10, 2023 | 11:08 PM
cagotzmann's Avatar
cagotzmann
Other limiting factors. Rear Spring. This is with 4.75 Backspace wheels. If using Ridetech coilovers this is not a issue.
Sway bar if installed.
Old Aug 11, 2023 | 01:09 AM
Scott Marshall
Thanks for the pics. Yes the rear spring clearance was a factor in my decision for coil overs. I'll have to get my car up and check the clearance with the frame rail too i guess.
Old Aug 11, 2023 | 11:07 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
The frame is the problem 6" BS will not work
Old Aug 11, 2023 | 12:02 PM
wheresmyhorsepower
I did a lot of research on this forum when selecting wheels and the most backspacing anyone has successfully used is 5.25" (without frame modifications). My rear wheels have 5.13" backspacing and clear when stationary but obviously contact when turning hard.
Old Aug 13, 2023 | 02:35 PM
Scott Marshall
Curious as to what size wheels and tires you are using on the rear that would come that close?
I may have to rethink my rear combo.
Old Aug 13, 2023 | 02:40 PM
TommyFox's Avatar
TommyFox
Save your coin and buy Get the Vansteel with the coil over mounts setup. No more worries about tire/spring interference.
Old Aug 13, 2023 | 09:10 PM
reno stallion
Still the frame is the problem. Coil overs will not help
Old Aug 14, 2023 | 12:07 AM
TommyFox's Avatar
TommyFox
On a 15x10 inch wheel the end of the spring rubbed on a 295. Coil overs cure this problem. But I went to a fiberglass VBP shortened spring as advised by VBP , no more clearance problem but the ride was terrible. Tried a few different spring rates and couldn't get a ride like the factory metal spring. Switched back with 17 inch wheels and and ran 315's on back. I always liked the look of the 15 inch tires better.
My plan this time is to have the Aluminum factory rear wheel widened by one inch and run 295's on the back with the coil overs. I saw it once and it looked fantastic...
Old Aug 14, 2023 | 09:40 AM
wheresmyhorsepower
They're 275/40R18s. The outer edge is nearly flush with the fender, pretty much identical to what cagotzmann shows in his pictures.
I can definitely see how the leaf spring would rub with 15 inch rims. The larger 18" diameter wheel allows the spring to fit inside of it instead of contacting a bulging tire sidewall. Van Steel makes 1/2" and 1" shortened composite leafs for additional clearance.
Old Aug 14, 2023 | 10:01 AM
red80468's Avatar
red80468
I like the idea of having the stock wheel widened
Old Aug 14, 2023 | 11:50 AM
reno stallion
Narrow the frame run offset TAs or coil overs and flare the fenders if you really want wide tires
To Ridetech Offset Trailing Arms
