Help with deciding
Old Aug 10, 2023 | 09:02 AM
Jason Davenport's Avatar
Jason Davenport
Default Help with deciding
I am trying to decide whether I should buy a crate 434 engine from nyes or Ohio crankshaft, or go with a 406 small block instead. I do have a set of brand new trick flow 202 valve 205 heads ported by tea I could use on the 406 and save some money. The other parts I have in the car are 3500 stall, 373 gear th 350, 850 quick fuel carb victor jr intake. The car will be 95% Street driven but I wanted to be a hot street car it'll only go to the track maybe once a year with some friends. I would like it to be able to keep up or beat some of the new cars. I'm not sure if the 434 would be too much for the street as I'm not trying to build a dedicated race car. The 434 from nyes is 630 hp I'm guessing 406 would be around 525 hp. Ty for any help I have to pull the trigger in a couple days. If I save the money on the 406 it would free up money to do other things to the car but I don't want to buy the 406 and wish I went with the 434 but I also don't want to buy the 434 and turn the car into a race car if if you get what I'm saying. Thank you again
Old Aug 10, 2023 | 01:24 PM
wwiiavfan's Avatar
wwiiavfan
You say you have 3:73 gear, but you haven’t said if you have strengthened anything south of the flywheel. This is important as it will determine what power level you can use vs what you want. 500 hp on stock drivetrain is about the limit and even that will be sketchy and you will want to run relatively skinny, traction limited rubber, so it acts as your safety valve. Guys on here have broken drivetrains on 350 hp.
If you want to run >500hp, be ready to upgrade the entire drivetrain, because if you strengthen one component, the weak point just keeps moving to the next component. Upgrading done right will probably cost you as much or more than your motor.
If you’re not upgrading the driveline, I’d run the 406 and not chase after getting every last hp, just drive it carefully and enjoy.
There are some very knowledgeable contributors on here that can fill in more details, but that’s about the gist of it.
Old Aug 10, 2023 | 03:21 PM
C3 Stroker's Avatar
C3 Stroker
Either the 434 or the 406 would be good street/strip choices. Both would drive about the same on the street, depending on your choice of converter if auto trans. It depends on whether you want a 10 second car or an 11 second car.
Old Aug 10, 2023 | 03:52 PM
Jason Davenport
Ty guys for your feed back and help. You are correct on needing to build the rest of the drive train to handle the power. I have addressed some of the areas but will need to address the rest. I spoke with Nyes I think I'm going to split the difference and go with the 427 SBC it has 550 horsepower. It also has a hydraulic cam and a 24 month 24,000 mile warranty and the price is in between the 406 and the 434. I'm essentially giving up 65 horsepower by not going with the solid roller 434.
Old Aug 10, 2023 | 07:16 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
i would go with the 406 for longevity...500 hp is pretty fun. enough to have fun and not blow up your driveline if it hooks up at the track. I ran summer high performance street tires and they would never hook up with 450hp, and I loved that 327
Old Aug 10, 2023 | 07:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
like said, not much difference.
and I agree that 406, all things equal, should out live the 434.
cam is the make or break street manners.
hell, I would go 434 because, you know,
more power
I wish I had your problem
Old Aug 10, 2023 | 07:27 PM
Rescue Rogers
it is big block territory without the weight... I would assume it would need a killer cooling system
Old Aug 11, 2023 | 08:16 AM
Jason Davenport
Are blueprint engines any good? I'm about to purchase an engine in next day or so and seen they have similar packages for 2 to 3k less. I'm not sure if it's just inferior product because you get what you pay for or if they make their money off of volume. Ty.
Old Aug 11, 2023 | 11:00 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Blue Print builds a quality piece. My buddy just got a LS427 decked out from them it is very nice.
To Help with deciding
