Drain plug
Old Aug 13, 2023 | 09:40 PM
garykuter's Avatar
garykuter
Default Drain plug
Is there a gas tank drain plug for a 77 Corvette and if so, where is it located. And if not, I need suggestions how to drain the gas. The car is been sitting for six months with gas in it and I believe I should change it unless somebody out there thinks different. Thanks everybody for the response.
Old Aug 13, 2023 | 09:51 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
no plug
siphon
un hook tank feed to fuel pump, gravity and removed cap
run it.
Old Aug 13, 2023 | 10:00 PM
garykuter's Avatar
garykuter
Originally Posted by calwldlife
no plug
siphon
run it.
so you think I should drain the gas tank if the gas is six months old? Or do you think I can get away with it?
Old Aug 13, 2023 | 10:05 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I have run old gas.
I fill it as quick as possible with Premium as I use it.
I have siphoned out at least half and filled with premium.
Your call and only you can make it.
Old Aug 13, 2023 | 11:09 PM
MelWff's Avatar
MelWff
Nothing wrong with 6 month old gasoline
Old Aug 14, 2023 | 07:54 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Nothing really right with 6 month old gas these days. I clean a lot of fuel systems in my line of work. Gasoline these days has a shelf life of approximately 3 months. I'd at least try to siphon out most, top up with premium and run that through. Then top again.
Old Aug 14, 2023 | 08:02 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Never had a problem with older gas such as yours or even older. If concerned, fill it up when you take it out.
Old Aug 14, 2023 | 11:13 AM
68V's Avatar
68V
Eh 6 months is pushing it with the quality of gasoline these days, just siphon out as much as you can, fill it up and drive it!
Old Aug 14, 2023 | 11:23 AM
69L88's Avatar
69L88
How full is the tank today? If nearly full, I’d throw a bottle of Sta-bi and a bottle of Heet and go drive it. If half-full or less, add the Sta-bil and Heet and add 5 gallons of fresh gas.
I agree with the others no need to drain.
Old Aug 14, 2023 | 11:37 AM
Fly skids up!'s Avatar
Fly skids up!
I have a Honda lawn mower. I use only ethanol free gas. With flesh gas it starts on the first pull. After two months, 2 or 3 pulls. After four months, 5 or 6 pulls. After six months, good luck!
Old Aug 14, 2023 | 11:45 AM
carriljc's Avatar
carriljc
6 months. no big deal. use it up.
Old Aug 14, 2023 | 01:21 PM
wwiiavfan's Avatar
wwiiavfan
That’s closing in on normal winter storage around here; we store with full tank to reduce condensation. Never an issue running that old tankful down to empty and refilling with fresh.
Old Aug 14, 2023 | 01:33 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yep.....30 years in the land of the Great Lakes makes you wise on how boat storage really should be.......and the people in the know store them with a full tank......some even plug whatever ventilation they have....no air or water gets to it....no problem.
Here in Texas......I just drain everything as it is dryer here......
Jebby
Old Aug 14, 2023 | 06:53 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
we use Stabil fuel stabilizer, it can sit for six months and still run....Without it and it was ethanol in the tank, it gets left on the side of the road. I got my brother a couple of snowblowers, my brother and Dad both a couple of lawn mowers all needing wither carb rebuilding or replacement. My friend caught on and he grabs what he can find and throws chinese carbs on them and gives them away...
To Drain plug
