Differential Spring Pack
Old Aug 14, 2023 | 12:40 PM
66RAY's Avatar
66RAY
Default Differential Spring Pack
I am working on a differential rebuild. Picked up a diff with 3.36. Thought I'd practice on my original diff which is a 3.08. Watched Tom's posi tuning videos and followed alot of the posts of Gary. First one went pretty well. I am in the middle of the 3.36 rebuild. I have Tom's shims and have both side axles shimmed to .005. I spun the posi 50 times in each direction on my old axle set up in my vice. Felt really good. Since I'm no expert I thought I'd reinstall the spring pack which I did. I put the posi on axle set up and cannot turn the unit by hand at all. I thought I read somewhere that the posi should spin with resistance but not extreme effort. Have I shimmed too tight? Thanks for any advice.
Old Aug 14, 2023 | 06:32 PM
69L88's Avatar
69L88
No need for the spring packs if you have tuned it as you have stated.
Old Aug 15, 2023 | 07:15 AM
66RAY's Avatar
66RAY
OK thanks. I'm going to do that. I did work the case as Gary has shown in his posts.
To Differential Spring Pack
