Carb Tuning with Advanced Camshaft
I have kind of a high level question for you all.
We know the ignition timing plays a huge difference in carb tuning, but I can't find much info on advancing or retarding the camshaft.
I rebuilt my motor a few years ago, and it runs pretty good, but runs rich at idle (12.0 afr), just off idle it gets a bit lean (14.2-14.19 afr), and is good on anything off idle (13.2 to 13.9 afr). When I rebuilt the motor I put in a pretty mild retro-roller cam and advanced it 2 degrees. Before I rebuilt the motor, it created good vacuum, about 17 inches at idle. Once I rebuilt the motor and advanced the camshaft, the motor makes even higher vacuum, about 19-22 inches.
Generally when the a motor makes less vacuum at idle, it's recommended to increase jet sizes...
Could the advanced camshaft be complicating my carb tuning?
I don’t think you need to change your carb jets just from advancing the cam 2 degrees. the intake valve is just shutting sooner.
I think the best way to pick jet sizes is an O2 sensor to check your AFR.
Gather data for part throttle pulls and WOT pulls and then adjust from there
I was just thinking if the motor creates more vacuum at idle, would you increase air bleeds, or decrease the idle fuel restriction
With those readings I'd work on the idle circuit to lean it. You could increase the idle air bleeds first as an easy change...but understand it might make that initial off idle lean spot a little worse....but you can tweak that with accelerator pump and/or PV adjustments/changes. You can also decrease the idle fuel feed restrictions...but that's more involved. Changing the jets to smaller isn't going to change idle behavior.
JIM
Tuning is determined by vacuum, swept volume, velocity and RPM......as well as heat and density.....moving the cam has very little play here.
Jebby
Jebby
I really appreaciate your advice on this topic.
Right now I have them about 9/16ths of a turn out right now, and it's really rich at idle. If i go 1/2 turn, it goes quite lean and off-idle gets too lean (like 15.2-15.5 afr).
Currently, even though off-idle is a bit lean, idle is really rich. I tried to remedy this by opening up the idle fuel restriction just a tad, but this makes the idle screws even more sensitive.
I tried opening up the idle air bleed a bit, but this made the idle to off-idle afr swings even worse.
The car feels good, but would just appreciate a more consistent AFR across idle, off-idle, and 10-100% throttle.
This is all on a 650 spreadbore holley.
I have a q-jet, and it has 'idle air bypass' orfice which would help with this situation. I guess i could start drilling the throttle blades on my holley, but from what I've read, that is typically done with not enough vacuum at idle
Jebby
Currently, my primary idle setting is really low, like 1/3 turn past touching the throttle lever. Transfer slot isn't square, it's less than square would be. Like a horizontal rectangle.
