Pressure Bleeding Master Cylinder
Old Aug 28, 2023 | 06:48 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Default Pressure Bleeding Master Cylinder
Will pressure bleeding the brake system, remove air from the mc or does it have to be bench bleed?
Old Aug 28, 2023 | 09:38 PM
cagotzmann's Avatar
cagotzmann
Here is the procedure I use to bleed the MC while on the car. Works without removing the MC.
Get the last bit of air out from the brake master cylinder. - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Aug 29, 2023 | 10:05 AM
HeadsU.P.'s Avatar
HeadsU.P.
Kind of a catch 22 question.
I assume the entire brake system needs to be bled, all six bleeders anyway?
Then it's more productive to remove the MC and place it in a bench-vise. Two fittings, two nuts and its removed.
Seldom can the last "unseen" bubble exit the MC using a Motive system.
Click on my avatar, look for photo album bench bleeding for some tips.
Old Aug 29, 2023 | 06:59 PM
ED DINAPOLI
Thanks guys, have not needed to do this yet, but I may have to drain my dot 5 and replace with dot 3. This means cleaning the whole system to get all the dot 5 out. The MC has never been off or rebuild in 51 years on my 72. I appreciate the info from guys that have used the pressure system for bleeding. I plan on using a motive pressure bleeder to remove the air.
Ed
To Pressure Bleeding Master Cylinder
