Starting up
Old Sep 1, 2023 | 08:58 AM
Golferdad's Avatar
Golferdad
Default Starting up
I have a 1981 and have done a lot of already replacing most of the engine parts,so I have done away with the ccc,and have replaced the heads up.so it was cranking,but 2 months ago,tore everything out of interior for new carpet and to paint everything,so did remove dash,gauges and radio and tach & Speedo cluster,have not messed with pulling anything under shifter,so it want crank now,hooked battery up and interior lights come on,olong with buzzer,but doesn’t even click,also I have a new starter on,so that’s not the problem,so decided to get under it and see if it would crank or at least turn over,which it did turn over,so does that mean I probably might have a wire or even ground wire disconnected. Thanks
