'Big' brakes on C3
Any pictures or part# of parts.
Is this what you are talking about ?
6061 J56 Brackets - CorvetteForum - Chevrolet Corvette Forum Discussion
The Corvette dealer and vintage racer Jim Glass (and a friend I often crew for), gave a machine shop in Montgomery NY a set of original cast iron ones to copy and duplicate in aluminum. I forget how many sets he originally made, but shortly after running them the shop got in trouble and folded. I understand the shop did work for Orange County Choppers and their downfall apparently had an effect on the machine shop too, but whatever the cause the CAD work disappeared with the shop. Jim doesn't have anymore of the aluminum reinforcement brackets, other then the ones on his race car.
The ones referenced in the link in post #31 above apparently went nowhere, since the OP hasn't been back on the Forum since January 2018.
Around 10-12 years ago a Dallas vintage racer had a company called American Race Components that made a run of alloy sets. While his website is still (somewhat) up, there's no mention of the reinforcement brackets, or any contact information on the site. I've sent a PM to Forum member C2Racer, who's a vintage racer from Texas, to see if Steve may know the company and how to reach them.
I know where there are a new few pairs of the ones Jim ran, in both the 65-68 small hole and 69-82 large hole versions. One set's spoken for, but there are a couple others left. I also have access to some of the reproduction cast iron 69-82 large hole ones. If anyone is interested PM me for more information.
OTOH I have an idea.
It would be nice to preserve the effort that went into that design.
I do have a little experience with 3-D printing.
Just enough to know that those pieces could be 3D laser scanned, and that would create a cad-cam file from the scan.
Then the file could be saved or sent electronically and any machine shop with a cad-cam router could make a set of these.
Once I ducted air to the center of the rotors and went to Hawk pads, I didn't experience any brake fade after that.
Front aluminum calipers & hubs.
That's excellent.
And great data logging software too.
I was able to get 1.29G out of my Pro-Solo 70 Camaro. But that was in an autocross setting at say 70mph.
I was using the super grippy Carbotech Superstreet FF pads (loved them), or the Performance Friction Z pads (dusty). (Dustiest pads ever, black wheels in 10 miles, but they worked). With Yoko 008Rs or Hoosiers.
Good thing it was short 90 sec courses because those pads would generate some serious heat and overheat if I used them on the high speed track. BTDT.
But they were great for the first half dozen stops! Even the 1st one.
I still had the rear drums on the Camaro with the factory single piston front discs & calipers. Nothing exotic at all except the pads.
The drums required full metallic race linings and vented drums to not overheat even on the 1st stop from 60mph, after I cranked the rear pressure up to make them work. Then they were fine for A-X. Not too grippy, but they would not fade, so I just cranked the rear psi up more. My L88 adjustable proportioning valve made a huge difference also. Like 25%! IIRC we started around 0.88G with early front lockup.
D8-6 Wilwood Disc Brakes - Search: 140-11857
What you have is one of these, based on rotor size.
Forged Narrow Superlite 6R Big Brake Front Brake Kit
140-10617
6-Piston Front Kit
14.00-in Rotor Diameter
1.25-in Rotor Width
18-in Min Wheel Dia*
140-10616
6-Piston Front Kit
13.06-in Rotor Diameter
1.25-in Rotor Width
17-in Min Wheel Dia*
140-12946
6-Piston Front Kit
12.19-in Rotor Diameter
1.10-in Rotor Width
15-in Min Wheel Dia*
He chose this because he wanted to go with an Old School look with 15” wheels. He’s going with an built 454 with a manual valve body trans. If it ever gets done. He’s been waiting forever. Big purchase for a 17yo.
My stock setup with Yellowstuff pads is amazing. No one needs more braking than that for the street. I really rip the crap out of my car and I know it stops.
So my advice is -
Power steering is a must, I can lock up all 4 wheels and did to stop about 3ft from an idiot doing a u turn in the road.
yellowstuff or equivalent pads are a must
decent tyres.
these are the 3 biggest improvements.
now we both have (I will soon) have 18” wheels. So I will eventually change to D8 wilwood calipers (just for the weight) and maybe 13” or 14” rotors. But none of that is to get better braking, it’s just weight and looks.
the other mods will achieve better braking.
