Calculate toyal timing?
Old Sep 21, 2023 | 07:18 PM
Shunyun's Avatar
Shunyun
Default Calculate toyal timing?
How fo I calculate what my total timing should be at max RPM?
Old Sep 21, 2023 | 08:40 PM
OMF's Avatar
OMF
You should contact @lars on the forum here and ask him for his timing paper, he's more than happy to help.
V8FastCars@msn.com
Old Sep 21, 2023 | 08:49 PM
lars's Avatar
lars
You don't calculate it. You determine it from dyno testing and from the cylinder head manufacturers' data. If you have stock iron heads, that number is 36 degrees for most small block applications, and can be up to 38 on the large bore applications. If you have aftermarket heads with good chambers, that number is 32.
If you're running boost, you have to do actual dyno testing to determine the curve and the number.
Nothing to calculate.
Old Sep 21, 2023 | 08:53 PM
MelWff's Avatar
MelWff
And that 36 degrees of mechanical advance should be all in by 3k rpm, not maximum rpm.
To Calculate toyal timing?
