Roll Bar recommendations?
Old Jan 22, 2003 | 09:58 AM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Default Roll Bar recommendations?
I'm thinking about ordering the 4 point roll bar from Jegs, but just got to wondering if it would interfer with the removable back glass in my 71. Has anyone used this roll bar and what was the result?
Thanks,
Dave
:cheers:
Old Jan 22, 2003 | 10:22 AM
groovyjay's Avatar
groovyjay
Default Re: Roll Bar recommendations? (Rolling Thunder)
I think Mike has one installed in his beautiful red 74. Hope he'll sees this topic. :cheers:
Old Jan 22, 2003 | 10:52 AM
Rolling Thunder
Cruise-In I Veteran
St. Jude Donor '03
Default Re: Roll Bar recommendations? (groovyjay)
You are right Jay, I saw his at Bowling Green and he did a great job on it. :yesnod: The reason I posted the question is that I think 72 was the last year of the removable window. You can bet I'll go to Mike for tips on fit, etc.
Dave
Old Jan 22, 2003 | 12:40 PM
SmokedTires's Avatar
SmokedTires
St. Jude Donor '05
Thanks Jay :D !
Dave, I actually installed the bar with the rear window out of the car, so that was one of the things I had to check for clearance when installing. I thought it would be important to be able to install/ remove it after the bar was in if I ever needed to in the future ;) .
If you decide to go for it, I can give you some tips :yesnod: .
Old Jan 22, 2003 | 12:54 PM
Rolling Thunder
Cruise-In I Veteran
St. Jude Donor '03
Default Re: Roll Bar recommendations? (SmokedTires)
Thanks Mike. As soon as I'm sure that it will not be a problem with the back window, I'm ready to cut the order. I took a couple of pictures of yours through the side glass, but they didn't show much. I'd love to hear what you learned on your installation and see any pictures you have of the installation. I'm also going to order the 5 point harnesses while I'm at it. Will I need to do anything special to the bar to mount them? While I'm at it, I thought I'd add a camera mount. Oh yeah, how much welding is required? I would assume the two kickers to the back would ship loose? And while I'm at it, is your's bolt in or welded to the frame?
Thanks,
Dave
Old Jan 22, 2003 | 01:58 PM
redvetracr's Avatar
redvetracr
Dave,
Why don`t you find a "short track" guy to bend up exactly what you want?? There must be like a million guys racing stock cars where you live. At least thats what I would do!! ...redvetracr
Old Jan 22, 2003 | 02:40 PM
Rolling Thunder
Cruise-In I Veteran
St. Jude Donor '03
Default Re: Roll Bar recommendations? (redvetracr)
Not a bad idea Red, I just figured it would be cheaper to buy from Jegs at @ $125. I also liked the way Mike's looked in the car. I'll check some locals before I order.
Old Jan 23, 2003 | 10:38 PM
Rolling Thunder
Cruise-In I Veteran
St. Jude Donor '03
Sorry, just thought I'd kick this one up to see if tonight's crew had any experience with the removable back glass.
Thanks.
To Roll Bar recommendations?
