Highest Volume (CFM) Electric Cooling Fan(s)
Old Oct 12, 2023 | 02:59 PM
TorchZ51's Avatar
TorchZ51
Originally Posted by L88Plus
^Thanks for the info!!!!!
I just ordered one for another project, $109 on Amazon with tax and free shipping, Genuine GM
you have a part number for the C5 fans?
Old Oct 12, 2023 | 07:18 PM
DblTrbl's Avatar
DblTrbl
Originally Posted by greg
what cfm do the camaro fans blow?
4188 cfm. But you really don't want all of that. The beauty of these fans is that they are variable speed. No need to blow that much air if the temps are low enough. There are controllers you can buy that will only let the fan run as hard as you need. Or for you DIY guys, there is info on how to make your own controllers in my fan thread on LS1 forums
Old Oct 13, 2023 | 11:11 PM
augiedoggy's Avatar
augiedoggy
Originally Posted by ctmccloskey
I have a 1988 C4 that came with the "Auxiliary Cooling Fan" installed from the factory. Under the hood you will find the large standard "Puller" fan behind the radiator and when you look carefully you will find the second fan and it is "Pusher" that pushes air through the radiator.
This was done by GM to eliminate the overheating of the C4's. It is very effective to have a pusher fan helping the cooling system. If GM does it why would it be a bad idea on other Corvettes?
pretty sure that fan was only to help keep the AC condenser cool..
