ARP Ring Gear Bolts
It not done correctly, the bolt will not be fully seated or bottomed out in the hole with a false torque reading. This may lead to the bolt(s) backing out in use and breaking, possibly wrecking the posi or locking up the diff. One conman that was on here did that with a cheapo 12 bolt build and the diff locked up.
It's a simple thing to overlook, it's not in any manual and most rebuilders use the cheap grade 8 bolts that come in the kits, not even shoulder bolts.
Good luck
I don't just install them. As anyone I have built a diff for can attest to, I check each hole and the case flange. Adjustments are made as required for full engagement without bottoming out or hanging up.
