I have a 1979 C3 - Does this year have a power window realy? Or just a circut breaker? The catalog shows 68-78. Neither window works after replacing motor. Circut breaker shows low ohms has continuity. Any help appreaciated.
Correction: WIndows work from console but not doors. I pulled CB from fuse panel an re-inserted. WOndering if the red wire under CB was effected when re-inserting CB?? Any experience appreciated. Also, looked for power window relay in assembly manual but could not find one. Is there one on a 79 C3?
Bikespace, Thank you for the docs and links. You fixed my power door window problem - they are for door locks - my new problem. I will look for door lock relay etc. and trouble shoot. I bought the car to drive and only been fixing things so far. I will get there!
No relays in the power switch circuit, either. You can get new lock actuators from Rock Auto. There is also a lubrication trick you can do. I'll add a link if I find it.
