Explain plugging from inside the tire
https://www.napaonline.com/en/p/BK_7...re=40055&nis=5
https://www.napaonline.com/en/p/BK_7...le&store=40055
https://www.napaonline.com/en/p/BK_7...ng_dcoe_google
https://www.napaonline.com/en/p/BK_7101643
Has anyone used some of these Patch Plug Kits and have one they recommend?
1 & 2 are different sizes. 1/4" is normal. That is #2.
You may also want one of these They cut thru the tire cords better, especially the steel belts, and make a round hole that seals better.
The steel belts have been known to cut external plugs in half.
Basically I use this bit with external tire plugs, on street cars, and hardly ever have a problem. But I keep an eye on the tire pressure too.
One plug recently still leaked and I had to double plug it. Not recommended maybe, but it worked.
For a high speed race car, that tends to heat up tires more, I might tend to go to the trouble to use the internal plugs.
Plus there is the whole centrifugal force thing at speed, and the T-plugs just get tighter.
there are videos online outlining the procedures.
Also, check with the local high school or community college program. Tire repair and balance is usually one of the required tasks if they are following a NATEF program outline.
C
there are videos online outlining the procedures. https://youtu.be/xKDZIUmy1RY?si=86UrtydSG7EiDGLN Is a sample.
C
So, I figured I pick them up, along with weight to rebalance. He does good work. Just don’t want to be a PITA asking for favors. Making him get parts he won’t otherwise use.
