Clutch question 75 Vert
1975 L48 Vert 4-Speed. Partially restored. Mechanic died halfway through. I took it over.
I finally have it running pretty good (thanks Lars and Jebbysan). Today, I took it off the jack stands and backed it out the shop and forward back into the shop. Wanted to see how the clutch and transmission engaged under a load.
The clutch catches very sharply about an inch or two off the floorboard. It is a brand new clutch and flywheel assembly.
Question 1: Should it catch so closely to the floorboard.
Next, I am having trouble grinding Reverse after moving the car a little. I have to slip the transmission into Second gear, then it will smoothly go into Reverse.
Question 2: Does the Reverse grinding mean I should adjust the clutch pedal to give more distance between clutch and plate?
I have not had an old manual/spring-clutched tranny in thirty years. Please give me a little guidance here.
Thank you.
Now that is gold nugget of information!!!
Thank you. I will check it.
Many threads on here in the past discussing this very issue. Certain brands of clutches simply do not dissengage enough with the limited travel afforded by the Corvette clutch linkage.
I would try readjusting the clutch with less pedal free play. But not less than 3/4 inch. If it still doesn't disengage completely, pull it out and replace it.
There are numerous threads on here as to which clutch is preferred.
And which ones simply do not work.
However, all forward gears shift smoothly with no force or grinding. When I stop, slip it into second or first momentarily, it then goes easily into reverse. Does that sound okay or may I still need to do more digging?
also see below..
also ebay 10 bucks or best offer free shipping for manual
i got my AIM from Willcox you should have that as well. and service manual
love the convertible! now let's see it on the road
You might also consider picking up an assembly manual and shop manual as well. All this will save you a lot of time, trouble and expense. Think of them, along with this Forum, as good investments. As for myself, I learn many things from them on a regular basis. I read many questions here on the Forum that are answered in the Owner's Manual, which is the most fundamental literature for a C3 Corvette owner. This is particularly true since the C3 is now a half-century old.
I sold two C3 cars over the years and each time I placed the appropriate Owner's Manual in the rear compartment so the new owners would have them available.
