Bolt help
Old Nov 16, 2023 | 08:04 PM
cottoneg's Avatar
cottoneg
Default Bolt help
Please see the attached pics. I need the size of the bolts in Yellow.
Bolt # 9418967
Bolt # 9419073
How do I find the size? I Googled it but nothing helpful came up.
Old Nov 16, 2023 | 08:29 PM
cottoneg's Avatar
cottoneg
I found this site http://www.camaros.org/forum/index.php?topic=11081.0
I plugged in the Chevrolet Bolt part numbers 9418967 and 9419073
I got this:
9418967-P79 3/8-16X3/49/16AF AMK B-10163 (2) Phosp B-10164 (2) Zinc
9419073-P95 7/16-14X1.05/8AF AMK B-13682 (4)
9418967-P79 3/8-16X 3/49/16AF AMK B-10163 (2) Phosp B-10164 (2) Zinc
From this I assume it is a 3/8 bolt, course 16 thread. Is the length ¾ Inch???
Same with this one:
9419073-P95 7/16-14 X1.0 5/8AF AMK B-13682 (4)
I think it is a 7/16 bolt. I am assuming Course thread. Can anyone decifer the length…Is it one inch?
Old Nov 16, 2023 | 08:44 PM
mbp's Avatar
mbp
Hello. Tried Google for the numbers and got 7/16 X 14 X 1" for bolt #94114073 and for bolt # 9418967 3/8 X 16 X 3/4", no mention of grade. Accuracy?, not sure. You might try the Corvette vendors vendors, sometimes in their description they mention the size of the bolts etc. Good luck.
Old Nov 17, 2023 | 06:15 AM
cottoneg's Avatar
cottoneg
I tried Zip and Keen. Both showed the bolt package with no measurements.
Old Nov 17, 2023 | 07:50 AM
70s's Avatar
70s
Bolt # 9418967
Bolt # 9419073
You are doing something that seems very commonly done by people on this forum.........using the "assembly" manual as a "parts" manual. They have different purposes. If you need to identify a part use the parts manual as parts manual often identifies the bolt sizes and grades. This is an example excerpt from the parts manual but not necessarily your solution. Yes, the information in the AIM and Parts manuals can often be very different. The issue date of the parts manual can also effect the results.
Old Nov 17, 2023 | 08:33 AM
Tiger Joe's Avatar
Tiger Joe
those numbers looks correct
the last part of the description there appears to be the socket size of the bolt head- 5/8 for the 7/16 bolt, and 9/16 for the 3/8 bolt
Old Nov 17, 2023 | 09:17 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You dont have a jar of bolts to see what fits?
Old Nov 18, 2023 | 07:20 AM
cottoneg's Avatar
cottoneg
Actually I found the bags with the old hardware I took out. It was in a safe place. So safe, I couldn't find it.
Everything I back in the car, The rebuilt starter, the new Power Steering Control valve and the rebuilt Muncie. Glad to get off of the cold concrete flood.
Thank you all for your help!
Old Nov 18, 2023 | 12:14 PM
Rescue Rogers
I put all my bolts and new small parts in that same safe place....im still looking for a few things from a few years ago....lol
To Bolt help
