electronic ignition
Old Nov 20, 2023 | 08:34 PM
vete76's Avatar
vete76
Default electronic ignition
whats involved in converting my 1975 corvette to electronic ignition? prefer not to change distributor
thanks
Old Nov 20, 2023 | 09:08 PM
n2h2o2's Avatar
n2h2o2
thanks
Don't you already have an HEI?
Old Nov 20, 2023 | 09:14 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
HEIs are hard to beat. If you have upgraded the engine, you could get a DUI HEI. It'll handle just about anything.
Old Nov 20, 2023 | 09:18 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Your 75 came with electronic ignition. Not much to convert. I'm thinking your just fine with your stock distributor if all you want is electronic ignition.
Old Nov 20, 2023 | 09:37 PM
augiedoggy's Avatar
augiedoggy
HEI is electronic ignition and all 75s were the first year to get it. There is zero benefit from installing msd boxes and such unless you taking this engine to 6500+rpm or need the ability to do things like retard the timing to start it due to crazy high compression or something..
This stuff is typically added because folks dont know any better and think it will make more power or reliability or are just looking for Bling under the hood they feel will impress others... I am not bashing it as ive got plenty of bling myself under my hood but I dont add things myself unless I feel they will improve my car in some way. My distributor on my 74 had points... So I bought a $50 HEI off ebay in 2012 and have been running it since. If I had a stock 75 HEI I would have stuck with that although Ive had no issues from my HEI other than the poor quality ignition modules that kept failing until I found a NOS delco unit on ebay also.
Old Nov 20, 2023 | 09:59 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
The stock coils on the stock HEIs are a limiting factor, and past 5000 rpm could stand improvement. Hence my DUI recommendation.
Plus they will "curve" it for you, which is more of a HP/TQ difference than you will ever see from any ignition alone.
Online quote: "I could run to 7,000 rpm with no problems at .035" plug gaps. Not on the factory coil though. I used Accel internal coils and Blue Streak HD caps and rotors with Brass contacts. Also, on an HEI distributor you absolutely MUST replace the high resistance carbon button that connects the coil to the rotor with a low resistance bronze button when using an upgraded coil.
The factory ignition coils and the high resistance carbon dizzy button are the real weak points of HEI distributor... not the module IMHO."
Old Nov 20, 2023 | 10:05 PM
Bikespace's Avatar
Bikespace
What do you consider "electronic ignition"?
The HEI that should* be in your car is a great system. You can dial it in a bit more with timing, perhaps enough to surprise you. Do you mean a programmable ignition curve?
*Should be, hence the picture request.
Old Nov 20, 2023 | 10:06 PM
n2h2o2's Avatar
n2h2o2
I had a 74 L-82 and it had an HEI, tach drive distributor...But I bought it like that so I am not sure if it was added or OEM...
I always thought it was original to the car...
Old Nov 21, 2023 | 04:46 AM
4-vettes's Avatar
4-vettes
I run a DUI Distributor. Which I installed after many attempts to properly curve a aftermarket HEI.
They curved the Distributor to my engine/car.
They asked a ton of questions about my engine and my car/ running gear.
Then they took a couple months to build a Distributor to match my engine and setup.
Then it took another month to get it to Australia.
Then I dropped it in. Checked it. Checked out spot on.
Then I drove it. ALL my problems were solved!
Bloody great piece of gear!
Bloody expensive over here in Australia compared to a Asian made Ebay distributor. As in 10 times the cost!
Worth every penny!
Old Nov 21, 2023 | 05:17 AM
randallsteel's Avatar
randallsteel
If you are referring to electronic programmable distributors, like progression ignition, they are awesome. I’m still dialing mine in, but the flexibility in the curve is great. And it makes using NOS much more convenient.
Old Nov 21, 2023 | 05:54 AM
Mr D.'s Avatar
Mr D.
Your 1975 Corvette came from the factory equipment with electronic ignition, there is nothing to upgrade.
Next question.
To electronic ignition
