According to the doc, the thermostat should be opening at 192°-198°F, which sounds like a 195°. I'd go with what GM recommended though a 180°F isn't going to damage anything. The higher operating temps helped to meet emission requirements. A tip to help bleed off air is to drill a small hole (~1/8") in the flange next to the thermostatic mechanism. This allows the trapped air to escape the block before the t-stat opens.
Even if you did have a drain on your radiator, I'd not touch it! They are susceptible to seizing from corrosion and will just snap off if forced. Yes, you can just pull the upper hose and lose maybe a pint or so of coolant. Might be a good time to remove the lower hose too and do a system flush. Make sure you thoroughly hose down any coolant from the driveway - animals like to lick it because it's sweet but it's highly poisonous and will kill them with kidney failure.
Recently did a pressure flush at friends shop. No need to remove any hose.
Funny thing is I just had NCRS judging, Top Flight award. One thermostat housing bolt had wrong head marking. So removed one bolt to correct that and now a slight leak. So have to put in new gasket.
As everything ran perfect I may just put the current thermostat back in.
I've done this job a few times and did so by first using suction and removing about a gallon of coolant by inserting a piece of clear plastic hose in the radiator, 1/4 inch inside diameter or so. This will allow you to replace the stat w/o problems with coolant leakage. When finished, just reinstall the coolant. Piece of cake...
Originally Posted by DRC
Think factory had a 198 thermostat, or should i just do a 180. DRC
The factory used the 195 thermostats for a good reason. The engine actually operates more efficiently at higher temperatures (it's a heat engine), so the 180-degree thermostat will gain you no advantage. Remember: The thermostat has no control over the maximum temperature of the engine. The thermostat only controls minimum temperature. If you have a temperature problem with the engine running hot, switching from a 195 to a 180 will do absolutely nothing to change the issue (unless the thermostat is defective).
As a side note to put this in perspective, one of the ways the NASCAR engine builders get so much power out of their engines is that they run the coolant temperature at 260-280 degrees (cooling system pressure up to 33 psi). And we see Corvette owners who go into panic mode when water temp hits 210-215...
Lars
Lars
Good point. Took out and cleaned up the thermostat. As a 38k mile car it may be the original one. See pic. I'll put this right back in with a new gasket.
And, car runs not hot at all. In Summer idling and checking with the IR Gun water neck, hoses, etc. show around 180.
Engine is as it left the factory. Except for lighter springs in distributor for 36 @ around 2,800.
While I agree with the thermo aspects of higher temps being more efficient........on a stock 350 in a C3 the elevated temps along with the hot heat riser port cooking things up for you....this is not a good idea.......you want some Vapor Lock? J
The other thing is NASCAR is not driving in traffic.......traffic raises underhood temps and intake air intake temps......
In the real world....cooler is better...to a point......
I like to see 170-190 depending on application.......
The LS argument of all of them running 210 is not valid because the LS engine has a plastic intake.......and perfect real time tuning.......
Jebby
Good points. Although I guess I got the best of both worlds. Engine and emissions as left the factory, 195 thermostat. Car runs around 180 once warmed up. Stays same sitting in traffic in summertime. Only change is I changed centrifugal springs to get 36 all in around 2 800 and pinned heat riser open.
I may be overthinking this but I went with a 180 thermostat over the 195 is for under the hood temperature and ever feel the "made out of plastic" hood after a long drive!!
The main reason Cup cars runs such high temperatures is because the opening to the radiator is so small, like the size of a pack of cigarettes to reduce drag. The high pressure cooling system came about when NASCAR limited the cooling system capacity to 2 gallons max.
