Side pipes and CCC
thank you!
My research turned up this: Denso 234-4209 https://a.co/d/5zzuvWZ
But I have not verified this will work. This is second hand info from another post on the forum which I have lost, though the O2 replacement remained on my Amazon wish list. The CCC is tuned to a particular O2 and I think this one matches it but adds the heater which is important because the side pipe collector is too far from the engine and too cold for unheated O2s.
Also you will have to get an O2 bung welded into the side pipe header collector. I chose stainless for my side pipes because I could weld in O2 bungs without sacrificing the integrity of a coating. Though you can get the mild steel headers and weld in a bung, I would just coat them after to stop them rusting.
Good luck, worst comes to worst just get rid of the CCC and keep the sweet side pipes.
