Speedometer driven gear
Old Dec 10, 2023 | 04:00 PM
mbp's Avatar
mbp
Default Speedometer driven gear
Hello. I have a concern and a question about the plastic Speedometer driven gear. My concern is how to install with out the whole piece going in to far and dropping into the transmission. First off is this even possible if the gear in the transmission is in place, it certainly seems possible with mine.
Do you put the driven gear into the sleeve and then into the side of the transmission as one piece, or does it matter. I'm afraid that when screwing the speedometer cable onto the sleeve it will push the driven gear to far in and into the transmission. Perhaps I'm looking at it wrong, any tips or advice. Thanks in advance.
Old Dec 10, 2023 | 04:59 PM
MelWff's Avatar
MelWff
Unless the drive gear has moved there is no way the driven gear will fall in. The gear is inserted into the adapter and than the adapter inserted into the transmission, it goes in as one piece.
Old Dec 10, 2023 | 05:01 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Truth - basically impossible.
Old Dec 11, 2023 | 09:21 AM
Arizona C3's Avatar
Arizona C3
Send it to John Dvorski at Redline Guage repair. (731) 571-0766 He updated my 82 speedo to 140 mph for a very reasonable cost.
Old Dec 11, 2023 | 09:29 AM
MelWff's Avatar
MelWff
What gives you the idea he has an 82? His profile says 69 which has a 160 mph speedometer.
To Speedometer driven gear
