Upholstery job
I didnt pay much attention to parts that will be covered with gauges or vents but those turned out pretty good too.
Here are some pics of the damn thing along with some more detailed ones. Keep in mind it’s still dusty and dirty, afer a good clean and cockpit spray it’ll be even better.
In the mean time last part of the dash is wraped. The under steering wheel cover part (dunno the name of this one)
Before
After
After - back side
Thanks.
Oh, and great thread so far. Fantastic work!
Shrinking? You are probably talking about this part:
It is not shrinking, it is extending. Prepare a small wooden block (it just needs to be angular for you to press in with it, not the correct size) and then there are three steps:
1. You put glue on both the vinyl and the surface
2. With a heat gun heat both the UNDERSIDE of the vinyl and the surface until glue evaporates all liquid content (30 seconds on low setting making sure you dont hold it in one place more than couple of seconds, holding the heat gun from about 8-10 inches away from the surface you are heating)
3. Glue two materials together and asap press the block in the indentation to strech the vinyl to form within the crevice
Most important advice: work no more than 2x2 inches at the time or you’ll lose the heat. When you press hold the block pressed for at least 2 minutes. That’s why you need the heat gun, the glue needs to be instantly sticky. Clamps are helpfull here.
I’ll try to video document my next piece and post it here.
So just not to think all is perfect, here is an issue that occured with the glove box. A giant bulge formed in the front.
By the looks of it, it seems that the old material underneath gave up or it was never glued correctly in the first place.
It was time to see what was going on.
Gently pry the lock out
with needle nose pliers unscrew the lock
This is how it will come out
Take the four screws out from the back
Peel off the new vinyl and here is the problem
we need to remove all of it and reupholster this panel
This is not leather, it is not the vinyl either. Just some kind of plastic moulded to dash.
This is bare plastic piece we are left with.
Now the new piece… cut to lenght leaving yourself a bit of material for a wiggle room.
Now add glue
make sure it covers every single bit of plastic, add the glue a bit thicker because we will fold the vinyl once for a glue stencil
after a fold we now see where we need to add glue on the vinyl side
Dry it with heat gun. Both vinyl and plastic side
once all the bubbles evaporated presss firmly from middle out
Repeat for the other side. Notice now we added glue to the lock indentation
After heating and firmly pressing the flat side, over the lock indentation we place some scrap vinyl and firmly press with a round object. Here the lock handle came in perfectly.
this is how it turned out
Now flip it and cut all the sides to 1/4 inch away from the plastic sides
Cut the corners by 45 degree angle but leave 1/8 inch of material from the corner as it will fold over the corner covering it up
again add glue and heat it up
Fold it over
and here is the final piece, notice the corners
now the lock… it will only go in one way. You need to insert the key first. When the backside locking mechanism is at 12 o clock as per standard, the cylinder will go in only when the handle tongue is pointing at 10 o’clock (in the picture I’m holding it the right way). Now before putting it all together you need to return it back to the dash with all 4 screws in place. Only then you can install the lock
This is how it is supposed to go in once everything is assembled. Oh, you need to raise the lock spring from the back side by your finger to allow the cylinder to slide in.
And there you go. Job done.
Now these are in order for rebuild and color change.
And as always, stay tuned…
As for used door panels I have no option on buying them because I don’t know anyone in the USA, no option other than new in Europe and mine look waaay worse then they really are. It’s mostly water damage and surface rust. Only thing that worries me is replacing inner felt. Seems originals were held by some kind of staple wire going through metal (never saw that one).
I have to research this.
Thanks for the help.
As always I’ll post update progress
Your panels don't look too much worse than mine were, it was mostly surface rust. The inner felts are stapled on, but you can replace them using self tapping screws as described in that thread, that worked for me.
I’ll update when I’m done
I know I shouldn’t be showing it just yet because I need to trim it and it’s missing the outer framing vinyl and it is not done and I need to make a pocket etc. but I am so psyched
This will be amazing on the doors
