Electric Choke Connection
Old Dec 13, 2023 | 04:37 PM
C3 73's Avatar
C3 73
Default Electric Choke Connection
Where should I connect the electric choke? Can I run a lead to the "+" terminal on the coil? Or should it go somewhere else?
Bubba wired it directly to the accessory position, so it's hot, literally, whenever the car is on AND in ACC! Guess how I found this out? OUCH!
Old Dec 13, 2023 | 05:32 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
I think the general consensus is to the wiper motor. That's where mine is wired to.
Old Dec 13, 2023 | 06:31 PM
MelWff's Avatar
MelWff
Look at fuse box IGN post. Do not connect to coil.
Old Dec 13, 2023 | 06:49 PM
C3 73's Avatar
C3 73
Thanks for the reply! I would connect it to the wiper motor, but that's another gremlin I have to track down and get working. I may just connect it temporarily to the IGN post on the fuse panel until I can get the wipers working. Maybe this will spur me to work on that as well.
Old Dec 13, 2023 | 06:52 PM
C3 73's Avatar
C3 73
Got it! No coil. Thanks.
The other suggestion so far was the wiper motor, but that isn't working at the moment, so I will go the route you suggested, at least temporarily.
Old Dec 14, 2023 | 06:56 AM
Bikespace's Avatar
Bikespace
GM used a relay in the C3s that had it stock.
There was another recent thread with some ideas....
Old Dec 14, 2023 | 02:04 PM
C3 73's Avatar
C3 73
Yes, you are correct! Two recent ones, actually. Those helped, too. Thanks!
Old Dec 14, 2023 | 02:28 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
I put mine on one of wires going to the blower motor resistors. It is on only in run position unlike the wipers which are on in assy.
Old Dec 14, 2023 | 11:58 PM
kossuth's Avatar
kossuth
The way we did it on my brothers 68 is we basically came off the coil hot (not directly, it fed a relay). Additionally we had an oil pressure switch wired into the oil system so that the coil didn’t get voltage when the engine was off but key on. Similar to the booster pump wiring on later carbed motorhomes etc. If you read the instructions on the carb it will likely inform you that there is a leak port around the coil and having the coil energized without a vacuum being pulled could burn out the choke coil.
Old Dec 15, 2023 | 09:36 AM
1860army's Avatar
1860army
I get that but in some cases like mine, having on with ACC works out. In the warm months my engine does not need much choke to start so I turn the key on for 30-45 seconds and then start it, that way it does not jump to 15-1800 rpms cold because the choke is already off the first step. Cold weather I just start it... Just a thought..
​​​​​​​60
Old Dec 15, 2023 | 10:57 AM
Danish Shark's Avatar
Danish Shark
And if you are like me, and don't like to see wires crawling all over your engine, then put the wire inside a piece of rubber hose like the one used for ignition vacuum, hides it nicely.
Old Dec 15, 2023 | 10:19 PM
C3 73's Avatar
C3 73
After reading 1860army's post, checking different places with a multimeter for where to wire the choke and checking a wiring schematic, it turns out the wiper motor is on the ACC terminal as well.
Old Dec 16, 2023 | 06:09 AM
BKarol's Avatar
BKarol
Oil pressure switch. One wire to the elec choke and the other to, in this case, tapped into the wiper motor wire. Current only active when there is oil pressure so working in the engine compartment with the key on acc does not activate the current.
Old Dec 22, 2023 | 08:29 PM
7T9Shark's Avatar
7T9Shark
If you have delay wipers, you can't tap into the wiper motor without affecting the delay function. I tapped into the IGN ON slot on the fuse block. Works great.
To Electric Choke Connection
