door open light
Old Dec 26, 2023 | 05:21 AM
hajb2's Avatar
hajb2
Navigator
Default door open light
the light on the dash tells me the door is ajar but they are closed where do I start to look for the fault thanks
Old Dec 26, 2023 | 05:56 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Try checking, adjusting the door ajar switches in the door frame. Switch at rear of door opening.
Old Dec 26, 2023 | 10:47 AM
Mooser's Avatar
Mooser
First press the switches by hand, (they are the ones at the rear of the door) and make sure they actually work.
If they do, check the little rubber pad on the door that hits the switch, they frequently fall off.
If the switch doesn't work you'll need to carefully remove them from the door jamb and see what's going on inside if a wire or contact broke off.
M
To door open light
