Brake Kit options
Old Dec 30, 2023 | 09:55 PM
Adollarwodbnice's Avatar
Adollarwodbnice
Default Brake Kit options
So my calipers are leaking and one has a seized bleeder nipple that snapped off and i've decided i'm just going to upgrade.
I've found a wilwood kit for front and rear for $1300 and change in red which i do like... would still need rotors. (https://www.corvettecentral.com/c3-6...82%2fbrakes%2f)
BUT, i can also just go with a rebuilt kit that has EVERYTHING i'm looking to replace and no more lip seals for about $1200. (https://www.corvettecentral.com/c3-6...82%2fbrakes%2f)
I am not going to race this car but i want the brakes to be very safe, do i just go with the rebuilt kit or are the wilwoods worth the extra money?
Old Dec 30, 2023 | 10:06 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Or if your calipers are what's leaking, you could just replace those for $450 with stainless steel sleeved calipers.
Almost zero reason to replace your rotors on these cars. They last 100k miles or more.
https://www.fullthrottlecorvette.com...ont_p_895.html
Old Dec 30, 2023 | 10:24 PM
Adollarwodbnice
I recently replaced some lines and bled the brakes and that's when i noticed the one leaking and the bleeder nipple broken off. I would have just rebuilt them but at these prices im thinking it's a good idea to just start fresh with new lines and everything. The previous 2 owners barely drove the car for the last 15 years and the 3 years i've owned it, the brakes have never felt great so i'd really like to make an improvement there. Just wondering if the extra money for the wilwoods is really worth it.
Old Dec 30, 2023 | 11:07 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
The wilwoods will not make it feel any better. If it does not feel great, you have an issue that needs addressed beyond leaks.
Look to internally swollen rubber lines, cheap pads, and improper bleeding.
Fix those three and it should stop great.
The Wilwoods are definately lighter. But they have the same piston and rotor sizes so it will stop the same. The seal design is improved. But if you go stainless sleeved iron calipers and o-ring seals, it should stop the leaking issues on those. Using the iron bore as a sealing surface just does not hold up on this fixed caliper design with it's small pistons.
Bleeding these brakes properly to get a good solid pedal is a challenge, regardless of caliper mfgr. It has to do with the 16 pistons. In fact the Wilwoods are more difficult to bleed than stock, the rear bleeders are too low.
Old Dec 31, 2023 | 12:00 AM
carriljc's Avatar
carriljc
I got the red wilwoods on group sale here on the forum in 2012. They've been wonderful. I was reluctant to spend the money but it turned out to be one of my better wastes of money .... My kit came with D6 fronts and D4 in rear with SS hoses. Haven't had a brake problem in the last 11 years.
Just get or make yourself a pressure bleeder. Ever since I started using a pressure bleeder the bleeding is easy.... even on these wilwoods.
If you can swing it...just do it.
Don't bother with the rotors unless you are sure they are bad
Old Dec 31, 2023 | 12:14 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm going to second the idea that replacing the rotors is most likely not necessary. Not only a big waste of money. But a HUGE increase in labor! You do realise that they are riveted on? And new ones will need to be shimmed for run out? Lot's of work that very likely is not necessary.
My car has over 100K's on it and my rotors look near new.
Old Dec 31, 2023 | 09:38 AM
cottoneg's Avatar
cottoneg
If the bleeder snapped off, that can be a bit of and issue. But I agree with the advice to go with stainless steel calipers. I did it many years ago and have never had an issue since. The fact that you bleed your breakes is great.
I can't see anyone needed more than the stock brakes for the street. As you mentioned, replacing the rubber hoses, new stainless steel calipers and cutting the rotors would make the car very safe.
Old Dec 31, 2023 | 10:43 AM
gg521's Avatar
gg521
Default brakes
If you do a little searching, you can find the Wilwoods for a whole lot less money elsewhere. I have the Wilwoods and prefer them over the stock calipers. Are they going to stop you better than the stock ones - maybe not a lot. Are they lighter-yes. Do they leak-no. Are they a lot easier to rebuild -yes. When you mount them, you may have to shim them to center on the rotor. You have to be careful on the rear calipers as the supplied bolt is not the correct length. Hopefully they have fixed this.
Old Dec 31, 2023 | 02:28 PM
kansas123's Avatar
kansas123
As far as the broken-off bleeder, I had one do that to me and I used an easy-out and it came right out easy.
To Brake Kit options
