75 Manual Courtesy Light Headlight Switch
Old Jan 8, 2024 | 06:48 AM
MPBS's Avatar
MPBS
Default 75 Manual Courtesy Light Headlight Switch
I searched high and low and haven't seen a whole lot on this issue. I recently replaced all of my bulbs with LED and for some reason when I turn the headlight switch counter clockwise, the courtesy lights do not come on. They do, however, come on when the doors open.....hmmmmm. Anyone seen this before?
Old Jan 8, 2024 | 03:54 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
It's possible when you had the dash panel out to change all those bulbs, you either knocked a wire off or perhaps a old wire just broke.
Or perhaps your switch is bad.
Sounds like you need to pull out that drivers side dash again.
