Plug wires
Old Jan 9, 2024 | 10:52 AM
NHollyy's Avatar
NHollyy
Default Plug wires
I’ve been wanting to get new plug wires. I have 882 heads, Doug D380-C side pipes, and the stock distributor. I wanted to ask what plug wires you guys have been running that won’t sit on the headers/any recommendations.
Thank you for any info!
Old Jan 9, 2024 | 10:54 AM
kansas123's Avatar
kansas123
Old Jan 9, 2024 | 11:14 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Taylor Wires and spark plug wire boots. Wire looms help direct your wires, many styles available so take your pick.
Old Jan 9, 2024 | 12:48 PM
Crimson Thunder's Avatar
Crimson Thunder
I like Taylor wires as well. Just make sure you get 90 degree ends at the spark plug and you will be fine. They clear my Hooker side pipes great.
Old Jan 9, 2024 | 01:01 PM
wwiiavfan's Avatar
wwiiavfan
Get the long wires that are meant to go underneath the exhaust. Then make or buy a couple small tabs that you can bolt into the threaded bosses on each side of the block underneath, and run a zip tie thru them to secure the wires away from the headers. Worked great with my Doug’s style side pipes. Super easy to keep them off the exhaust this way.
Old Jan 9, 2024 | 02:56 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
custom make them...its a good skill to have and they will be perfect...buy a good plug wire crimping tool...maybe watch some professional videos
Old Jan 9, 2024 | 04:52 PM
ctmccloskey's Avatar
ctmccloskey
I totally agree with Rescue Rogers as I am not paying the "going" prices for today's Spark Plug Wires.
I have a Big block and like avoiding hot areas so custom built makes sense as it allows so this requires a little more wire here or less there. The tools are Inexpensive and the wire and misc parts are readily available. I am using an old MSD tool from the early 1980's and I would say it has paid for itself. The last time I bought a Pre-Cut Ignition Wire Kit for my 1968 C3 they were over $150 and that is just not right, especially when you price out the do it yourself and compare. The parts cost a fraction and the installation is simple enough for "virtually" anybody to do it.
To verify your good work simply open your hood after dark. It should be nice and dark in there as the ignition sparks should be under control.
Old Jan 9, 2024 | 07:07 PM
blue427's Avatar
blue427
I use Accel ceramic wires on my bb with large hooker headers and side pipes,no more burnt wires,ever.
Old Jan 9, 2024 | 08:07 PM
Rescue Rogers
I just bought those ends to swap onto my wires...great idea
Old Jan 9, 2024 | 08:19 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Just make your own custom set for your application. I used bulk 8.5mm MSD wire and cut to exact lengths and installed ceramic boots on the ends so that the headers don't burn them, works perfect. Much cheaper than buying ceramic wire set and works just as good. You will need a spark plug wire crimper, but that doesn't cost that much. GL
Old Jan 9, 2024 | 10:36 PM
Bikespace's Avatar
Bikespace
I bought a wire loom that bolts to the valve covers, and cut the wires to length. They don't touch my Hooker sidepipe headers, and the loom feeds them into the gaps, and keeps them from crossing.
Old Jan 10, 2024 | 06:14 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
another vote for make your own with ceramic 90* boots
Old Jan 11, 2024 | 12:18 AM
lars's Avatar
lars
See my response on this subject here:
https://www.corvetteforum.com/forums...ion-wires.html
Lars
Old Jan 11, 2024 | 07:41 AM
Chagjr's Avatar
Chagjr
https://www.zip-corvette.com/57-74-2...lug-wires.html
With 90° angle boots.
Great price! Easy install, no heat concerns, I have raced 3 cars with these wires.
Best Bang for the buck.
Old Jan 11, 2024 | 07:17 PM
60 SHARK's Avatar
60 SHARK
I agree,,,, make your own. . I always run plug wires under the exhaust, , out of site and cleaner look. I have a box full of junk old valve cover loom blocks, etc , that I ditched from customer cars. LOL The drive me crazy
Old Jan 12, 2024 | 09:44 AM
stingr69's Avatar
stingr69
What boots did you get? Seems they cost more than the "cut it yourself" ceramic boot wire kits? Jegs wire kit was less than $100 and has very good snap-on terminals.
Old Jan 12, 2024 | 01:08 PM
Rescue Rogers
$93 bucks at Summit.....But I should have them until I break them...could be forever or 2 weeks..
Pertronix straight boots for my big block
https://www.summitracing.com/parts/PNX-8502HT-8
Old Jan 12, 2024 | 01:18 PM
Rescue Rogers
Just looked at the Summit price and its gone from $93 to $114...They went up $21 bucks in 4 months...A custom cut to fit wire set is around $145 bucks now
Old Jan 12, 2024 | 03:20 PM
stingr69's Avatar
stingr69
Yep, that is a lot.
I would look at these. Wires AND ceramic boots. Nice terminals.
​​​​​​Jegs Wires
To Plug wires
