Do I need strut rod bushings caps
Old Jan 9, 2024 | 04:17 PM
Jackk's Avatar
Jackk
Default Do I need strut rod bushings caps
I am ordering rubber press in strut rod bushings. Do I need the bushing caps as well.
Old Jan 9, 2024 | 07:05 PM
69L88's Avatar
69L88
If by “caps” you mean the washers that sit between the bushings and the attach points, then if they aren’t mangled and/or rusted and/or worn badly, you should be good to go with what you have.
Old Jan 10, 2024 | 11:11 AM
Jackk's Avatar
Jackk
My original strut rod bushings had no washers between the bushing and the bracket to which they attached. Should there be a washer in between the end of the new bushing and the bracket?
Old Jan 10, 2024 | 03:15 PM
GTR1999's Avatar
GTR1999
There are "mushroom", "cap", or "T" bushings- whatever you want to call them, on both sides of the rod end in the differential bracket but there are none at the bearing support. The steel bushings take up the play in the bracket, if you don't have them in place there will be play.
Old Jan 10, 2024 | 03:20 PM
Jackk's Avatar
Jackk
Thank you for your response, that is what I needed to know. I will order four. J
To Do I need strut rod bushings caps
