brakes
Old Jan 18, 2024 | 01:24 PM
7T3stinger's Avatar
7T3stinger
Default brakes
I have had 2 sets of napa calipers, and they have leaked ever since put on. Was looking at putting Lonestar calipers on. Ive seen and read good reviews. Has anyone had a bad experience with them? Just curious. I've read all about how good Wilwood's are, but I don't want to spend that much. It's not a track car and I don't race it. I drive it on weekends and maybe a couple days a week. Thanks for an info and opinions.
Old Jan 18, 2024 | 01:36 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
About 80% of all C2/C3 caliper leaks are caused by rotor runout. There isn't a caliper made that will not leak eventually with a wobbly rotor......make sure you check yours.....
Lonestar calipers are high quality and I recommend them.....
Jebby
Old Jan 18, 2024 | 01:46 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
n=1
I had an outer boot seal that was pinched during assembly and leaking on a front Lone Star lip-seal caliper a couple years ago. Since I use DOT 5 fluid, I didn't attempt a return and rebuilt it myself. Upon disassembly, I was surprised at the lack of polish on the stainless sleeve and the relatively coarse honing marks. It had definitely been sleeved some time ago and, I believe, had undergone at least a couple rebuilds since the sleeve insertion. I decided to rebuild the other front caliper too so that I could inspect the sleeve finish and saw a similar condition with that one. Polishing took a few hours and were definitely better surface finishes afterwards — no problems since.
Old Jan 18, 2024 | 01:51 PM
interpon's Avatar
interpon
through vendors.. i have had 2 lonestar calipers leak (within last few years). one at 11 months and another at 8 months. Under warranty and replacements so far ok..
if you have stainless bores.. i would DIY new pistons and o rings... #3 caliper is done that way zero issues several years.
#4 caliper never leaked in 5 years and one half is DELCO the other blank LOL.
Pick your poison..
there are new re-pops too.. available.. most all through vendors are 1 year warranty..
i would return the NAPA under warranty and get $ back.. probably chinesium like the other chains anymore
Old Jan 18, 2024 | 02:27 PM
Tampa Jerry's Avatar
Tampa Jerry
As mentioned above, check the runout, it should be under .003. If the rotors are within specs, and the calipers you have now are out of warranty, open the calipers to determine if they have been sleeved in stainless steel. If so, consider rebuilding them with O-rings. I did this on my 66 and 68 over 10 years ago and have experienced no leaks. Jerry
Old Jan 18, 2024 | 02:32 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If you cant take your new NAPA calipers back for a refund, take them apart and se if the cylinder bores are smooth and pit free, its also helpful if they are stanless steel lined. IF they are smooth buy an oring kit for $85 bucks and rebuild them yourself. I got my kit from CSSBINC 3 or 4 years ago and they still arent leaking. You can buy the complete o-ringed calipers from them also. Just avoid the stupid lip seals altogether...total waste of time. What ever you get use the correct DOT fluid recommended by the manufacturer.....
https://www.cssbinc.com/corvette-calipers.aspx
the lip seal ones and the o-ring seals are the same price
complete set
https://www.cssbinc.com/caliper_rear_set-1.aspx
Theh wilwood set would be $1250 for 4 of the DB8 stock calipers which are lighter and aluminum
the Lonestar site is down right at this moment...no price avaliable
Old Jan 18, 2024 | 03:30 PM
barkingrats
DANG, RR, had to duck two stones on that one!
Old Jan 18, 2024 | 03:33 PM
Rescue Rogers
oops...just trying to help someone avoid my paste failures
To brakes
