Can anyone decipher 200 4R trans serial #?
Old Jan 21, 2024 | 06:39 PM
TommyFox's Avatar
TommyFox
Default Can anyone decipher 200 4R trans serial #?
121-860KCF1800
328-881CHF0212
Neither are the coveted BRZ Grand National but I have no idea exactly what they are. Looking to swap out the TH350
Old Jan 21, 2024 | 08:45 PM
gjohnson's Avatar
gjohnson
Pull the pan and look for the code on the valve body.Thats the identifier
KZF -- Olds 442/Hurst
CZF -- 85-88 Monte SS
CRF -- 85-88 LG4 305 powered Monte Carlos/Pontiac Grand Prix
BRF -- 86-87 GN/T-Type/Turbo Regals
BQ -- 84-85 GN/T-Type/Turbo Regals
BR -- 83 Model T-Types
TAF -- 89 Turbo Trans Am
OZ -- Hurst Olds
OM -- Olds 350 Diesels
OG -- lds 307
BY -- V-6 252 Cars
AA and AP -- Cadillac's
Old Jan 21, 2024 | 10:10 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Originally Posted by TommyFox
121-860KCF1800
328-881CHF0212
Doesn't really matter as you can stuff all the good stuff into them.
Old Jan 22, 2024 | 05:15 AM
TommyFox's Avatar
TommyFox
Thanks. KCF and CHF are not on the list so I can't tell what it came out of.
Old Jan 22, 2024 | 09:05 AM
speedreed8's Avatar
speedreed8
I think all the letters end in F. Maybe a v6 model. CH. KC
i have a CQ in my 79.
Old Jan 22, 2024 | 10:19 AM
ratflinger's Avatar
ratflinger
Originally Posted by RamJet502
What?
All the GN parts as well as even better aftermarket internals are available to substantially strengthen a 200R4
Old Jan 23, 2024 | 05:51 PM
TommyFox's Avatar
TommyFox
Yeah, was hoping to get a decent used one and throw it in.
Old Jan 23, 2024 | 10:10 PM
ratflinger's Avatar
ratflinger
Then you should also buy lottery tickets
Old Jan 23, 2024 | 10:18 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
valve body is the key, even though kits are available, I have the impression
gran national ones are drill different and have different dia valve bores?
governors can be swapped.
Old Jan 24, 2024 | 04:34 AM
ratflinger's Avatar
ratflinger
Get the ATSG for the 200-R4. It will explain any differences between units.
Old Jan 24, 2024 | 11:11 AM
Eric P's Avatar
Eric P
The main differences are the valve body separator plate hole sizes and calibration of the valve body itself, in late 1987 they changed the 3-4 accumulator housing design . they do have 5 different wiring schematics depending on valve body pressure switches , if it has 3rd gear pressure and 4th gear pressure switch ,or 3-4 pressure switch only , 3-4 pressure switched with 4th pressure switch and last the 4th gear switch only .... some valvebody's can have Lockup in 3rd gear and 4th gear , some just 4th gear ... the govenor has different tooth count for rpm shift points , more teeth for higher rpm , less teeth for lower rpm shift points , Trans-Go and Sonnax have valve body calibration kits for the 200R4
Old Jan 27, 2024 | 09:39 AM
TommyFox's Avatar
TommyFox
Debating if it's worth the trouble to buy a so called used 'good' transmission and have troubles only to have to pull it again.
Old Jan 27, 2024 | 09:50 AM
ratflinger's Avatar
ratflinger
People do, but it's Russian Roulette
Old Jan 27, 2024 | 02:04 PM
TommyFox's Avatar
TommyFox
I got a used one from a wrecked Buick GN back in 1998 with 50,000 miles and installed it in a 1978 Trans Am.. It worked flawlessly. I don't think I will get that lucky this time.
Old Jan 27, 2024 | 02:33 PM
gjohnson's Avatar
gjohnson
Why would you not rebuild a USED trans. before install?
To Can anyone decipher 200 4R trans serial #?
