Another ATF thread
Feb 11, 2024 | 07:54 AM
Another ATF thread
Okie Dokie. Here goes another one.
So, 1982 Corvette CE. 700R4 Trans. Just got it and want to do a full maintenance pass.
Lots of opinions out there on what ATF to use, so I guess this is more of a poll.
- Transynd 295 - Sounds like this is best?
- AC Delco Dextron VI - I hear this will work but may be too thin and could cause issues over time.
- Redline D4
- Lucas Oil Multi Vehicle ATF
Which is best? Or is there another one that is better?
Feb 11, 2024 | 06:52 PM
St. Jude Donor '22
type III dex equivalent.
called Dex/Merc now.
good luck
Feb 12, 2024 | 01:14 PM
Should I look for Full Synthetic or no?
Feb 12, 2024 | 04:31 PM
Feb 12, 2024 | 07:29 PM
St. Jude Donor '22
Quote:
Originally Posted by
Tim7282
your choice
just be sure is DexIII compatible
Feb 13, 2024 | 02:03 AM
Valvoline Maxlife is an excellent fluid to add to the list.
Feb 13, 2024 | 07:34 AM
68post
agree, it's what I use and I'm not gentle on my TH350.
Feb 13, 2024 | 11:43 AM
When mine came out of warranty in May of '77 the 1st thing I did was install a B&M shift kit with their blue trick shift fluid.
It's the only fluid I've used & I still bark 2nd gear..
Feb 13, 2024 | 12:20 PM
REELAV8R
Likely easier on trans fluid than my use in work trucks, I do beat the pants off of them. My 4L80 has 310,000 miles now.
Feb 18, 2024 | 01:22 PM
OK so gathering all the knowledge I can, here is the final analysis: 1982 700R4 calls for Dextron II
Dex/Merc non synthetic is Dextron III which is backwards compatible to Dextron II and the preferred choice.
However, Dex Merc Synthetics like Valvoline Maxlife red bottle, is Dextron VI compatible
Dextron VI is apparently not ideal for the older transmissions due to being too thin and negatively affecting components over time.
Therefore, a Dex/Merc non-synthetic is the preferred choice for the 1982 700R4.
The non-synthetic Valvoline DEX/MERC in the blue bottle seems to be the correct choice.
Feb 18, 2024 | 05:51 PM
Feb 18, 2024 | 08:30 PM
St. Jude Donor '22
Tim7282
glad you investigated
