Engine replacement
Old Feb 11, 2024 | 05:03 PM
Dave D's Avatar
Dave D
Default Engine replacement
So I’m back. Haven’t posted since about 1997…. Finally decided to do some upgrades to my 81. Over the years I’ve done the interior, suspension, bushings etc. Finally doing some engine work. I had a known long time engine builder build me a 350 four bolt, with 400 heads and a mild cam. He thinks it will be about 350 to 400 hp which is perfect. Time to pull the old smog motor out. Do any of you have any experience in this? I want to put a whole serpentine system on it but I am wondering if it will fit under the hood. I’m also worried about the intake and the 650 carb he put on it and if the hood will close. Just curious before I tear this apart. Current smog motor runs great and all the smog stuff is gone but my 3500 ram truck will still smoke this car easily. I’m torn between leaving this car alone and putting the new engine in something else some day. Have to do something with the new one….. already have a LOT of money invested and more to go. Any thoughts? Much appreciated.
Old Feb 11, 2024 | 05:20 PM
gjohnson's Avatar
gjohnson
You need to factor in rear gear set/TQ convertor.in the equation.Doesnt matter how much HP you have if you have the stock gear set that comes w/ a 81,you'll never spin the wheels
Old Feb 11, 2024 | 06:00 PM
Dave D's Avatar
Dave D
I plan on replacing the trans and converter. Would love overdrive, but not a deal killer. But didn’t realize I’d have to change the gears.
Old Feb 11, 2024 | 06:19 PM
gjohnson's Avatar
gjohnson
Your truck has most likely 3:70 + gears.81 Vette came w/ 2:72 or 2:87 gear set. 400HP wont spin the wheels. Id go at least 3:55
Old Feb 11, 2024 | 06:36 PM
Stormin_Normin's Avatar
Stormin_Normin
Adding some stall with the torque converter will help with the tall gears. I would think 2200-2400 range depending on the cam specs. You’re pretty limited on serpentine options, but there are threads here on what will fit. I opted to go with a 700r4 when I swapped engines because the swap cost wasn’t much more than the rebuild cost.
Old Feb 12, 2024 | 07:40 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You need torque to pull that gear and that means 383 or 406......I wouldn't even bother building another 350......especially with 400 heads which were marginal at best......and unless those heads are ported, you will never see 400hp......odd choice of head to spec, unless the guy just had them laying around.
If your engine is sound......modify it. Put some real heads and exhaust on it......
Nobody can tell you if the intake will clear because you didn't tell us what it is. The "650" carb has nothing to do with it......
Need more info...
I built a 385ci for a friend in an 81' and it is a beast with 700r4 trans......rear gear is stock.
Jebby
Old Feb 12, 2024 | 09:55 AM
Eric P's Avatar
Eric P
700R4 transmission is perfect for that gear ratio , recommend a higher stall speed regardless of transmission choice , set of aluminum heads with small chamber would help a bunch
Old Feb 12, 2024 | 10:45 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Skip White sells cheap aluminum heads that can make big power
Old Feb 12, 2024 | 11:02 AM
Bikespace's Avatar
Bikespace
Welcome back to the Forum! Everyone seems quick to tell you what you should have done. Why not just swap the engine and see what else needs to be done? It's really easy to spend money on more parts. Spend money on gas, tires, and cheeseburgers instead!
A $700- gantry crane from Harbor Freight might be a safer way to pull the engine, and cheaper than hiring a mechanic.
Please post some photos of the completed engine, unless I read tour post incorrectly. If there's still time to kibbitz, buckle up.
To Engine replacement
