will it fit????
Old Feb 13, 2024 | 07:57 PM
Bills17n72's Avatar
Bills17n72
Default will it fit????
hello i have a fanblade with the clutch , its from a 77 , a forum member was wondering if it will fit on a 19
68 327 , any ideas? thanks Bill
Old Feb 13, 2024 | 08:27 PM
Greg's Avatar
Greg
Just another Corvette guy
If it measures 18 1/4 inches in diameter it should fit the '68. I think the standard fan for '68 was originally a 5 blade. Replacement fans listed as fitting "All 1968 to 1982" but they are a 6 blade. The extra blade on yours will only help.
Old Feb 13, 2024 | 08:55 PM
Bills17n72's Avatar
Bills17n72
thanks greg!
Old Feb 13, 2024 | 10:19 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The water pump hub pilot nub may not match the fan clutch hole. The pilot diameter changed, I believe, in '72 — the earlier hub pilot was 5/8" while the later was 3/4".
Old Feb 13, 2024 | 10:40 PM
Bills17n72's Avatar
Bills17n72
thank you 67:72
Old Feb 14, 2024 | 01:09 AM
Greg's Avatar
Greg
This is correct. Many aftermarket pumps used to come with a bushing to fit over the hub pilot to take up the slack. Don't know if they still do, but you should be able to locate one without too much problem, pretty sure Summit offers them for a few bucks.
Old Feb 14, 2024 | 01:15 PM
wwiiavfan's Avatar
wwiiavfan
OP, measure that diameter carefully. My car when I got it had what looked like a regular Corvette fan, but turns out it was 19” diameter. (I think I determined it was from an Olds 442 or something). Anyway, it actually contacted and cut the lower rad hose, since my shroud extension was missing. I trimmed the blades down. It was easy, they are aluminum, and I was careful to remove the exact same amount from each blade so as not to upset the balance. Been working fine for thousands of miles.
To will it fit????
