So I know I’m gonna get different answers on this, but what is the best spark plug for my 77 vette 350 motor? And is there a spark plug? That would give me more torque? Probably not, but I figured I’d ask.
I have been using Accel plugs for 40 years with good results. Had some bad experiences with Champion many years ago, and their aviation plugs are notoriously bad so I avoid them. I've had good luck with NGK in most of my other toys but I've never tried them in a SBC.
And no, spark plugs won't affect power output, assuming they are in good condition.
I think the consensus (at least among car guys) is that no brand or style of plug will increase power or torque in anything less than a high rpm race-only engine.
For street cars, the difference comes in how each brand or style of plug performs under less than ideal combustion chamber conditions (too rich, too lean, oil fouled, carbon fouled, etc.)
As mentioned above: If the engine has the CORRECT plugs for the engine build, different plugs won't make more power. However, depending on the ignition system you have (points / electronic) plug GAP can make one heckuva difference.
I put NGK irridiums in my SB car...because they last a LLLOOOONNNGGG time...and I didn't want to mess with the spark shielding stuff any more than absolutely necessary. If you don't have to deal with that, any good brand of plug will do the job.
P.S. I am no longer a fan of ANYTHING sold in a GM labeled box.....
I have an electronic ignition. I was thinking about doing the NGK plugs anyway. Do you gap them them at 0.45?
I have tried many different plugs. Champion (the worst), Accel Yellow jackets, the Bosch 4 electrode plugs, AC Delco (second best), and NGK (Best).
One thing I noticed was after I tracked the car (Time Trials) the car had issues. NGK was the only plug I could street, track and then drive home with no issues.
BTW: NGK has excellent technical service dept. Call them up and tell them about your engine, how you use it and they can recommend the right plug and the correct heat range for you.
