Recommendations for hidden antenna
Old Feb 23, 2024 | 02:25 PM
KENS80V's Avatar
KENS80V
Default Recommendations for hidden antenna
When I bought my 1980 Corvette in 1983 it had a mast antenna. I later changed to a aftermarket power antenna but didn't like the fact it protruded slightly from the body. I'm in the middle of a body off restoration currently and thinking of glassing the hole and going with a hidden antenna. Does anyone have any recommendations?
Old Feb 23, 2024 | 02:35 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I just a bought a Dakota digital one but i havent installed it yet. It has mostly good reviews. You could look into that one..
Old Feb 23, 2024 | 08:14 PM
LT1M21Vette's Avatar
LT1M21Vette
<u>amazon</u> amazon
Don't expect a better reception than with a stock antenna, but if you are close enough from the station, you should be ok.
Old Feb 23, 2024 | 10:29 PM
redbird68's Avatar
redbird68
I used a Retrosound hidden antenna in a 68 firebird years back, works great.
Mounted it in the trunk, screwed into the metal panel behind the back seat.
Old Feb 23, 2024 | 11:18 PM
Richard Daugird's Avatar
Richard Daugird
I was thinking about the antenna that came with my Sirrius Radio, and sat on the dash. Then I realized, it probably wouldn't work for FM. Then I wondered, why would anyone even listen to FM anymore anyway? I live near Houston, one of the biggest cities in the country, and there is no longer an oldies station, the so-called classic country station(which played a bunch of 90s-up garbage) is now gone, and only one classic rock station that plays ten minute(I have time it) commercial blocks. Sirrius radio is like a dollar a day, and internet radio is free. Sorry, just had to vent.
Old Feb 24, 2024 | 09:15 AM
LT1M21Vette
It will not work. Different frequencies.
Why do you care?
We all have different listening habits, and that's cool.
Old Feb 24, 2024 | 02:33 PM
Crimson Thunder's Avatar
Crimson Thunder
SiriusXM is way less than a dollar a day. Sign up for a free month
subscription and let it expire. they will send you coupons in the mail for $5 a month.
Old Feb 24, 2024 | 03:08 PM
carriljc's Avatar
carriljc
I installed a manually retractable antenna ages ago....just to fill the hole. I don't really listen to the radio but I can pull it out to put on a little flag for this, that, and the other occasions..... It does work and I have to say it looks better than an antenna always sticking up. Not much of anything to electrically fail or break either..... and it works if I ever turn on the radio.
Not sure where to even find one nowadys? Probably amazon or ebay?
Old Feb 24, 2024 | 04:01 PM
TommyFox's Avatar
TommyFox
Not sending one dollar to that reprobate Howard Stern.
Old Feb 24, 2024 | 07:37 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
You can get them at Crutchfield. I bought one and the reception is better than the fixed mast I had.
Old Feb 24, 2024 | 09:16 PM
carriljc's Avatar
carriljc
Wow. That was simple. Good find. Not that I'd ever expect mine to wear out. Cheap too. I like it.
https://www.crutchfield.com/S-hR8VRk...CABEgLAVvD_BwE
Old Feb 24, 2024 | 11:20 PM
Richard454's Avatar
Richard454
Originally Posted by LT1M21Vette
amazon
EXACTLY!!! I got rid of cable and wanna watch the local new occasionally- every "digital" antenna I tried was crappy.
I used a $29 regular old TV antenna - put it in the attic and it works great. BTW- the whole FM band is between the over the air channels 5 and 6.
The metal body cars work much better with ANY antenna- as the car's body acts as a ground plane.
Look at the metal plate GM used under the antenna to help- back in the day.
Top of the gas tank would be the best choice- just don't screw it into it!!!
Old Feb 25, 2024 | 12:07 AM
Bikespace's Avatar
Bikespace
Your phone has an antenna, and Bluetooth.
Amazon (for example) will stream much higher quality music than the radio, including Sirius/XM radio.
Don't glass the hole. Plug it, and save it for a future mod.
Old Feb 25, 2024 | 12:16 AM
LT1M21Vette
The broadcast FM band is above the old analog TV OTA channel 6 (83.5 MHz).The old analog TV OTA channel 6 audio carrier was at 87.75 MHz.
Old Feb 26, 2024 | 08:34 AM
Richard454's Avatar
Richard454
HA- been a while since I messed with that- when I worked for Kenwood - several of their radios would go 87.75 and you could listen to the TV station- So it's between channels 6 and 7.
Old Feb 26, 2024 | 09:35 AM
LT1M21Vette
FM broadcast is right after channel 6
Channel 7 starts at 174 MHz.
Television Frequencies.
Old Feb 26, 2024 | 01:33 PM
Richard454's Avatar
Richard454
I guess my point - lost in translation -is a 1/4 wave antenna is around 30"- Which is going to be tough to beat in performance- as I don't see a 1/2 or 5/8 wave antenna as practical on a vette!
To Recommendations for hidden antenna
