Hei cap & rotor
Old Feb 25, 2024 | 12:48 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default Hei cap & rotor
How often should I change the stock cap and rotor on my ' 77 ?
Old Feb 25, 2024 | 02:26 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Don't want to find out the hard way !
Old Feb 25, 2024 | 05:40 PM
MelWff's Avatar
MelWff
Look at the condition of the two components. If the center button on the cap is worn or the contacts around the perimeter are burnt, replace the cap. Same for the rotor.
Old Feb 25, 2024 | 06:16 PM
lars's Avatar
lars
On my C4 I changed them out every 100,000 miles whether it needed it or not. I never saw any erosion or wear, or had any ignition system problems, at 100,000 mile intervals. I changed them 4 times, and did not change them when the engine hit 500,000. I sold the car at that point.
Old Feb 25, 2024 | 06:46 PM
lickahotskillet's Avatar
lickahotskillet
If you let the plug gap get too wide, the spark will punch a hole in the bottom of the rotor. Look on the bottom of the rotor for evidence of pencil dots. Check the sides of the coil for over heat rings. They can punch through & go to ground. Examine the cap inside and out for jagged pencil lead looking tracks. Examine wires for hot spots where they cross or sit on anything.
Do you park in a dry garage or in a damp area. Warm/hot cars are a magnet for moisture & ignition problems.
Old Feb 25, 2024 | 07:18 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Thanks guys!
Old Feb 26, 2024 | 10:02 AM
LT1M21Vette's Avatar
LT1M21Vette
As often as needed?
I like to use one of the big brand, MSD, Accel, Pertronix. Maybe others have a different opinion?
To Hei cap & rotor
