Alternator sizing
Old Mar 4, 2024 | 10:05 PM
Dave Culp's Avatar
Dave Culp
Default Alternator sizing
I have a 1973 coupe with A/C and auto trans. A prior owner had replaced the original 61 amp alternator with an 80 amp chrome job (probably from Jeggs?). I don't know if the replacement was done just to get a shiny chrome part, or if it is because the car has electronic speedo and tach. Or both. In any case I'm restoring the car to original and just bought a correct numbered and date coded 61 amp unit.
Here's my question. Would it hurt anything to install the 61 amp alternator now and leave the electronic speedo and tach for a later date? Let's say I'm driving home from a car show at night with the A/C on (very likely to happen out here in the desert). Will bad things happen?
Old Mar 4, 2024 | 10:12 PM
BLUE1972's Avatar
BLUE1972
the 61 will work as long as you have the original headlights or LED that pull less amps.
The key is to watch the draw when it rains and the wipers are on with the A/C at a stop light or stop and go traffic. .
I drive my stock 72 with A/C all the time. Since its an auto, do what I do and sometimes put it in Neutral if I'm stuck in heavy traffic - that helps at stop lights and traffic.
Old Mar 4, 2024 | 11:00 PM
ZIOGEO's Avatar
ZIOGEO
Its fine. Back in the late 80's I had a 71 Mustang with AC, a 55 Amp alternator and 3 audio amps that pulled 30 amps (at peak) and had no problems in general. However to offset the high load I used the highest capacity battery that would fit. Drove that car for 5 years and only got stuck once where it wouldnt start.
Old Mar 4, 2024 | 11:03 PM
ZIOGEO's Avatar
ZIOGEO
Old Mar 5, 2024 | 07:30 AM
Richard454's Avatar
Richard454
As far as additional load of the electric speedo and tach- that is very minimal-probably less than 1A-no worries at all.
The 61A correct alt will work fine- as long as it is correctly rebuilt and indeed does put out the rated amount of current. Just a guess- that chrome 80A might
have made 80A OGD (on a good day!!!)
Also note the 61A alt's max output is at about 1800RPM- not at idle. So sitting in traffic would be the issue- not driving down the road,
Richard
Old Mar 5, 2024 | 03:54 PM
7T1vette's Avatar
7T1vette
The "new" stuff that really eats power is an electric coolant fan. If you still have the stock fan system, 61 amp alternator is fine...even with electronic speedo and tach.
Old Mar 5, 2024 | 04:28 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
with the two above post's.
Old Mar 5, 2024 | 09:02 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I would take the armature from the chrome one, and put it in the original case.
and best parts
To Alternator sizing
