New ping
Old Mar 25, 2024 | 05:15 PM
drwet's Avatar
drwet
Default New ping
Late last summer my car ('79, 427 small block, TKO 600) started pinging at part throttle around 2000-2200 rpm. My differential diagnosis includes ignition timing, stuck power valve, and bad gas. Alcohol free premium is getting hard to get in Canada and I suspect the station where I have been buying my gas may have started adding ethanol.
I checked my timing today. Here is what I got. It is unchanged from what I charted last year so I'm thinking it's not timing. I'd appreciate any input.
Old Mar 25, 2024 | 07:01 PM
HeadsU.P.'s Avatar
HeadsU.P.
You don't need Ethanol free. In fact, Ethanol increases octane. So thats not your issue.
Ethanol Free is a "storage" fuel for long term parking of carbureted engines.
You have something else going on.
Check the plug wire routing of # 5 and # 7. Make sure that from the cap, all the way to the plugs, those two are well separated.
Use your wire looms to keep them on opposite sides of the loom.
Your pinging may be Cross-Fire-Induction. Number 7 may be firing before 5.
Old Mar 25, 2024 | 10:01 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
What's your manifold vacuum reading (ie: vacuum advance timing contribution) at the 2000-2200 RPM load point where it pings?
Old Mar 25, 2024 | 11:52 PM
drwet's Avatar
drwet
I have about 12" at idle. About 18" at 2000-2200 but that's no-load. No idea what it is under load.
Old Mar 25, 2024 | 11:55 PM
drwet's Avatar
drwet
Excellent suggestion. Thank you. That's exactly the kind of ideas I am looking for. I doubt if that's the problem as I can't imagine how that would start suddenly, but I will definitely check it out.
Old Mar 26, 2024 | 10:32 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
carbon build ping.
had it.
Old Mar 26, 2024 | 10:41 AM
drwet's Avatar
drwet
Originally Posted by calwldlife
carbon build ping.
had it.
How did you resolve it?
Old Mar 26, 2024 | 12:36 PM
REELAV8R's Avatar
REELAV8R
If you suspect alcohol in the fuel you can test it. Just put a little water in a see through tube/jar and mark the water level. Add gasoline. If the water rises above the mark then there is ethanol in the fuel since ethanol will readily mix with water. If it doesn't rise then it's pure gasoline.
Old Mar 26, 2024 | 03:24 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If it is pinging at part throttle.....it is most likely the vac cannister.....unplug the cannister and go for a ride.....does it stop?
Ethanol has zero to do with it......
Jebby
Old Mar 26, 2024 | 03:59 PM
HeadsU.P.'s Avatar
HeadsU.P.
drwet,
If you have a std vacuum gauge it likely came with about two feet of hose.
You can go to a parts store and purchase about six feet of that hose. Find a Vac port you can tap into.
Run that extra long hose into the cockpit thru an open window. You can leave the hood unlatched, won't hurt a thing.
Go for a ride. Notebook and pen.
Note different RPM ranges and jot down your vacuum reading.
What you don't know yet is where your Power Valve is opening (or should open). You might be running lean until the P.V. kicks in.
What number is stamped the P.V?
Old Mar 26, 2024 | 06:18 PM
drwet's Avatar
drwet
Jebby
Thanks for the suggestion. I did try that last Fall just before I put the car away. It did not solve the problem, and on the same ride I developed another problem that took priority so I didn't get a chance to chase it further. I may repeat the experiment in the Spring. This time, if disconnecting the vacuum canister doesn't help, I'll start backing off the timing until the pinging stops. I have to admit though, I was getting the distinct impression that it was not related to ignition timing. I would have expected some change in response to disabling the vacuum advance, and there was exactly zero.
Old Mar 26, 2024 | 06:25 PM
drwet's Avatar
drwet
drwet,
That's an excellent suggestion. I was toying with the idea of installing a vacuum gauge in the cockpit, but it's getting crowded in there. I'm really not even thrilled with the AFR gauge I have mounted in there but that's just too useful to give up. But I digress.
The PV is the 6.5 that came with the carb. What is your philosophy when it comes to PV selection? I've heard more than a couple over the years, none of which impressed me as very logical.
Old Mar 26, 2024 | 08:37 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Check for burned plug wires....look lnto methanol injection.....try using seafoam to steam clean your pistons and valves, maybe it will scorch off the deposits...or just use water in a spray mist bottle hold your rpm up to 2500 rpm and mist above the carb...it will also steam clean the pistons if its a deposit issue.
Old Mar 26, 2024 | 08:40 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
SeaFoam.
Old Mar 26, 2024 | 09:04 PM
HeadsU.P.'s Avatar
HeadsU.P.
The old fashion way of P.V. selection was to take a vac reading at idle and cut that number in half.
But with big cams and a car with dozens of vacuum accessories, it's tough to get 13 inches = 6.5 PV.
Old Mar 27, 2024 | 10:51 AM
drwet's Avatar
drwet
The other school of thought seems to be to go closer to idle vacuum. I have about 12” at idle. I’m thinking of trying an 8.5. Any thoughts?
Old Mar 27, 2024 | 10:53 AM
drwet's Avatar
drwet
SeaFoam.
I assume you pour some down the carb with the engine running and let it soak for a while? Run it and change the oil?
To New ping
Old Mar 27, 2024 | 11:04 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
that is what the bottle says.
good luck
white smoke is carbon.
first time I used it, smoke bomb
Old Mar 27, 2024 | 07:34 PM
HeadsU.P.'s Avatar
HeadsU.P.
No thoughts. Power Valve tuning is an art.
I tried one size up. One size down. Little effect.
At $25 a piece, you don't want to keep doing that all day.
I did notice on Ebay years ago, that you can get a bag assortment P.Vs all within a few inches of each other a lot cheaper than individually.
Some tech forums said to stay away from "two-stage" and avoid those power valves with huge windows. Racing valves, not street.
Stick with original Holley or QuickFuel parts.
Maybe Lars will stumble on to this thread.
Old Mar 27, 2024 | 08:10 PM
drwet's Avatar
drwet
Yeah. Next time I'll title it 'Carb problem'.
