72 C3 gauge issues
I initially noticed that I was reading no oil pressure - engine fires and ticks over fine, and sounds good. Then noticed no battery voltage reading and no change in the water temperature, so I'm thinking/hoping I'm simply missing a common ground or live feed to these? They were working a couple of weeks ago.
In addition I have the door ajar light on permanently. Fuel gauge also seems to work correctly.
So are there any common ground or live that may have come loose here that I can investigate? I did see a hanging wire with a ring on the end which looked like a possible ground hanging down by the starter - could this be it?
in to the dash. It is not an electrical ,unless something else was changed. The other problems can probably
be traced to a ground problem. Good luck to you.
On the back of the oil gauge, is there a spaghetti sized plastic tube connected? That's the oil pressure line – it has a small bit of oil in it from the engine that presses on the mechanism at the rear of the gauge. (Do not disconnect the line from the back of the gauge and run the engine. You'll be cleaning up oil from behind the dash for quite a while.)
Does the temp gauge have the 3-prong wiring harness connector firmly seated? If so, go to the driver's side of the engine and see if the single wire is attached to the small temp sensor screwed into the head between the 1st and 2nd spark plugs.
The door ajar light is controlled by the plunger switch at the very bottom of the door latch end of the door opening. Is it there and does it plunge OK? You can unscrew it and gently pull the switch out to be sure the wires are on the contacts and not touching each other. Takes maybe 2 minutes to pull and put back.
Sounds like I need to get in behind the gauges....will do that as soon as it stops raining as I need to pull it out of the garage to get the passenger door open!
