Install help for new distributor
Old Apr 20, 2024 | 10:08 PM
Doug C.'s Avatar
Doug C.
Default Install help for new distributor
Hi everyone,
I'm going to replace my stock distributor with this one from Zip:
https://www.zip-corvette.com/62-74-dragon-fire-pro-series-electronic-distributor-w-tach-drive-red-cap.html
Does anyone know the install for a direct stock replacement? I already installed the upgraded coil as suggested in the item description. I think the wires coming out of the dizzy with the black coupler are only used with EFI (which I don't have) and the grey wire connects to the negative of the coil. Is that accurate? Appreciate the help.... Wish these things came with a diagram!
Old Apr 20, 2024 | 10:17 PM
Doug C.'s Avatar
Doug C.
I take it back, there was a diagram! Went under my bench when pulling it out. Anyway, the coil hook up is now clear, now I'm confused by the grey wire. Help appreciated!
Old Apr 20, 2024 | 10:29 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I see your dilemma. Diagram shows it going nowhere.
best quess would be a electric tach signal wire. Which could be used with EFI or a electric fuel pump shutoff relay. Best guess is you don't need it. Tape it off.
Old Apr 20, 2024 | 10:59 PM
Doug C.'s Avatar
Doug C.
Thanks, this is where I was leaning too. Will update once it's in.
Old Apr 22, 2024 | 12:38 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Why not just call Dragon Fire at 888-732-7718 (M-F 9-4 PST) and ask what the grey wire is for since it's not on their diagram?888- 732-7718 888-732-7718-732-7718888-732-7718
Old Apr 22, 2024 | 06:20 AM
wwiiavfan's Avatar
wwiiavfan
Might be that they use the same wire harness on tach drive vs non-tach drive, and the gray wire is a an electronic tach signal?
Old Apr 22, 2024 | 09:07 AM
Doug C.'s Avatar
Doug C.
Well, I can report that the distributor works fine with that grey wire taped off. I can also report that the grey wire is charged and needs to be taped off because with my initial crank I didn't tape it and it arced. Will call Dragonfire this week to see if I can solve the mystery for a future forum member who has the same question. Thanks everyone.
Old Apr 26, 2024 | 03:06 PM
Doug C.'s Avatar
Doug C.
I talked with the rep at Dragonfire and the grey wire is for an electronic tach. That's a strange thing to have on a mechanical tach distributor but here we are. Thanks for the help everyone.
Old Apr 26, 2024 | 04:36 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Did you tell them to UPDATE their diagram? Funny how companies put out great information, but FAIL miserably to get it correct 100% of the time.
Old Apr 26, 2024 | 05:16 PM
4-vettes's Avatar
4-vettes
No, not strange. Imagine that you decided to install a aftermarket EFI system. It would need a tach signal so it could operate. So although it's a mechanical drive distributor it's set up for carb or EFI. Also highly likely they use the same guts in this mechanical drive distributor as they do in a later distributor.
Would be nice if they included that information on the instructions. Someone out there might connect it to ground and burn out the distributor.
Old Apr 30, 2024 | 02:32 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Maybe that's the reason... Then they could sell another distributor!
Old Apr 30, 2024 | 07:23 AM
kossuth's Avatar
kossuth
Not strange at all. A tech feed is used for more than just a tach. It’s actually a common trigger mechanism for programmable nitrous window switches where nitrous is engaged between A-B rpm.
Old Apr 30, 2024 | 01:55 PM
Doug C.'s Avatar
Doug C.
That makes sense. Appreciate the help everyone.
Old May 1, 2024 | 10:28 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
If that Tach/C- line got grounded, the distributor/module should be unhurt. The coil, on the other hand, may fry itself as the coil effectively goes into 100% dwell time (ie: toaster mode), and it's just a matter of if the coil can survive the high current/wattage that it would experience while the ignition key was on.
To Install help for new distributor
