What is the name of connector plug for the two wires that connect to alternator? the one on my car is worn out and I would like to have that plastic plug just don’t know what to search for
I found one on Ebay. Red & White wired, GM correct. And came with about a 10" leads / pigtail.
Plus has the snap / clip to secure in place. You will need a soldering gun.
That little terminal "pocket" has a tendency to collect engine grime and jeopardize the connection.
With the red cable wire removed off the back of the ALT, you can take a Q-Tip dipped in carb cleaner and safely clean the area.
