Front clip adjustment.
[Modified by Solidlifters, 6:15 PM 1/30/2003]
Second thing is do you want to stick with the custom nose? It's already been damaged, and you probably will not get it to line up without removing it completely, in which case you may want to consider a new one. Go to this thread that I posted a while back, and print the reply from Phils79. http://forums.corvetteforum.com/zerothread?id=462618. Also the Ecklers book on fiberglass repair is pretty detailed on this subject. Gather all the info you can, decide your couse of action, and keep posting. No question is stupid, what that guy did to your car before IS stupid..
is lifting that high in the front without making ungodly cracking sounds.
If this is the case, you should be able to pull the fender outward - just in front
of the door (at the bottom). If the bond is broken, it will pull right out a few inches.
If not, then pulling outward slowly and cautiously can break these bonds in
a pretty clean manner. This is how I got the cowl bonds on my 75.
Now, the firewall strip across the top is tricky. I used a couple woodworking chisels
to work that bond and slowly split it along the length. Some folks make a cut
about 6-8 inches in and only split this much off - but that bar helps to maintain
the opening for the hood - so I'd try to keep it intact. Take your time, and
you can do it.
You may have to break the bonds to the corner mounting piece - shown
attached to the top in the bottom photo. My windshield frame was so rusted
that the rivets were only holding on to air.
Here's a few pics from my website:
NHvette.com
[Modified by NHvette, 1:26 PM 1/31/2003]
