Can Heads Combo
Can Heads Combo
Hello, I have a 79 L82 and I was wanting to “wake it up” I saw a video on a head and can combo for a comp cam XE274H and the heads are no longer available to purchase. I have an intake and carb already but I was wondering what a good head combo would be for the cam. My bottom end is good and I have checked it out so I was just wondering for the heads and cam with stock bottom end. Thanks
Received 4,660 Likes
Cruise-In VIII Veteran
I'm running Edlebrock heads as an example. Just about any aftermarket aluminium head is a upgrade from your stock heads. Many love the AFR's. But they cost a bit more.
Basically, your looking for 64cc combustion chambers and 180 runners.
Your budget will determine which ones you go with.
I went Edlebrock as they are medium price. Decent quality. AFR's were out of my reach.
been running them for 7 years and many thousands of miles.
96 lt-4 (05-04-2024)
Just pick a good set of heads replace the timing chain and advance the cam 4 degrees and you will be surprised. Chevrolet ground no advance into thier cams. Set up the curve in your distributor. It will run pretty good.
Im also running Edelbrock E-Street heads. Happy with them as well, just needed to work out the choke.
Highway Man
Sorry for not adding much for camshaft choice and cam/head combinations but for cylinder heads, MotorTrend Engine Masters TV show, ran a test on 'low buck" SBC aluminum heads.
Season 7 Episode 15 - Low Buck SBC Head Shootout (2022)
Air Flow Research (AFR) Enforcer Line comes out on top but like everything these days, the price has gone up significantly
Cheers,
Richard
Cheers,
Richard
Any aftermarket 64 cc aluminum head at that build level is going to give you a good boost in power. You aren't running Pro Stock where 10 more horsepower is the world. Shop your budget.
The following 3 users liked this post by 7t9l82:
When I did my engine years ago, Summit racing had Edlebrock heads on sale. With FREE shipping! (Within the U.S.). That made up my mind.
had them shipped to a shipper in LA. put in a container. Many months later I had a pair of decent heads at a fraction of the price Australian seller's were asking.
Shop around. If you find something of interest and are not certain. Ask on here if anyone is running them.
Cheers,
Richard
Cheers,
Richard
I am so impressed with mine I just bought a 406 with brand new never ran edelbrock heads which I will be removing to swap these heads onto after I pull them from my cars current engine.
These are the exact heads I am running (again only I bought mine bare and ported and loaded)
https://www.ebay.com/itm/35163322920...3ABFBM-JL5ludj
Alternatively you can buy them from afr through speedway with quality machinework and hardware for about $1200 for the pair still
So I’ve been looking into all the heads options you all have been recommending. Any opinion on Flotek heads? And should the 180cc be a deal breaker or is a 190-195cc okay?
For what your looking to do. 190 heads will work fine. Very little difference.
