quadrajet carburator part identification
Hi All:
Apologizing in advance because I don't know the name of the parts, so doing my best to describe them.
Have a 1970 corvette SBC350 with a quadrajet carb. While driving, the acceleration got stuck. Looks like there is a mechanical issue at the carb, and I need help to identify what the part is (and what is does would be helpful, just for knowledge) so I can fix it.
So the throttle has a lever that sits on top of, and pushes down, a large-pin (see attached diagram), and also has a small thin-pin attached that leads into a rectangular housing. My car is missing this rectangular housing and the small thin-pin. The lever (see other attachment) is not sitting on top of the large-pin, but off to the side and is getting stuck against the pin that it should be pushing down. What are the name of the parts I'm missing (rectangular box and small-pin) and anything else??
Hello. The larger pin works the accelerator pump and is needed. The lever should be on top of the large pin and not hanging up or slipping down the side. That lever that pushes the large pin down is help in place by a small pin, perhaps the pin is missing and allowing some play in the lever?
The small clip/wire that goes into the rectangular box in the first picture but not yours is not needed, don't worry about that one.. The clip/wire or whatever that goes into the rectangular box was connected to a rubbery flapper that would lift ever so slightly at idle. It was there to be another vent but I believe it was done away with by your year. That was because they made an effort not to release to many gas fumes to the atmosphere. there are other vents that do more than enough. What ever Lars says is correct and if different than me I apologize and ignore what I said. Good luck
Sayfoo (05-10-2024)
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,963 Likes
Based on an e-mail received from the OP, I have sent him the following response and info:
"You have a hacked, commercially rebuilt carb that has been pieced together from several non-1970 parts and components. You are missing the bowl vent components, which have nothing to do with your problem, and they have bent and misaligned your accelerator pump lever. You also have at least a dozen other problems with that carb - it is a hack-job. See attached article about just a few of the problems your carb has."
Lars
Lars
mikiemike46 (05-10-2024)
The lever does indeed need to be on the top of the large pin (accelerator pump). It's normal to have a little wobble, but not enough to alow the lever to slide off the pin.
Perhaps you could bend/adjust the rod/linkage that is attached to the lever to get the lever aligned correctly.
And, you can shim the lever at the pivot pin to take out some of the wobble. Small C clips?? If not, you could remove the lever and bend it a bit to line up correctly. Do NOT try to bend the lever in place, as the ears of the carb that hold it in place are made of aluminum/pot metal, and could break off. This would not be good.
Removing the lever is a bit of a project, as the pivot pin is inserted from the out side and must be removed from the inside, out.
Seems that you have identified the problem, and now just need to fix it.
Thank you
Thanks for all of the responses and advice. It's encouraging that some people will still take their time to help others, without anything in it for themselves.
I'm sure the carburetor, along with most of the rest of the car, has been fixed incorrectly throughout the years. Right now I'm just trying to keep it running, but at some point I hope to have the money and knowledge to fix it up correctly! I think I have what I need until the next problem arises (guaranteed within a month)
Thanks Again!
Thanks Again!
The 1970 350 auto trans carb looks like this:
If you have a 4-speed, the carb looks like this:
Lars
