Stuck Headlights
Old May 11, 2024 | 03:29 PM
Alan Walters's Avatar
Alan Walters
Default Stuck Headlights
Hi,
The headlights on my 71 C3 are stuck in the open position.
There is no vacuum to the headlight relays.
I have traced and checked the vacuum hoses in the engine compartment, they are in good condition (replaced about ten years ago) and have tight connections.
The override switch under the dash has no affect.
Where do I go from here?
Alan
Old May 11, 2024 | 05:39 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Lay on your back. Slide your head under the front of your car. Reach up and grab the linkage about in the middle near the adjuster bolt. Pull. Headlights will come down.
Then. check your vacuum system. Do you have vacuum to the override switch? This one is easy to reach. Did a vacuum line come off the headlight switch?
No vacuum to the small line on top of the relays is headlights up. Vacuum to the small line on the top of the relays is headlights down. Do you have vacuum to the HVAC system?
Old May 11, 2024 | 07:04 PM
Mooser's Avatar
Mooser
Vacuum troubleshooting 101
https://www.corvette-101.com/vacuum.htm
M
Old May 11, 2024 | 07:55 PM
A10pilot's Avatar
A10pilot
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^The above link helped me trouble shoot my system ('69)^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old May 12, 2024 | 09:45 AM
Alan Walters
Thank you, this is very helpful!
Old May 12, 2024 | 06:39 PM
Peterbuilt's Avatar
Peterbuilt
Here's the part to pull down on, be careful near the switch (#8) as they are easy to break.
To Stuck Headlights
