Headlight vaccum leak
So my headlights wont pop up which most likely means I have a vacuum leak somewhere since I've heard these cars are notorious for having these issues. Is it okay if I just ignore the problem temporarily? Or is this something that needs to be addressed immediately? I'm asking because I have other things to fix on the car such as leaky valve covers, a broken tach and no interior lights. I just don't know how serious this issue is and if it can cause other issues if it goes ignored.
StDomingos (05-17-2024)
I guess it would be a problem if you are out and all of a sudden it gets dark. You can manually open them so I might suggest you learn how to do thatnow, rather than waiting until it gets dark.
You will find that your vacuum leak will also impact your A/C / Heater Control Vacuum switch. More than likely all air (switch setting in Vent, A/C, Defrost or Heat position) will only blow out at the floor vents.
Received 1,270 Likes
Many times the seals in the actuators fail, this might be your problem and these are the seal kits you might need.
You can open the headlights by pushing UP from underneath.
To close the lights pull down on this part:
Headlight trouble shooting:
https://www.corvette-101.com/vacuum.htm
It's not a problem at all. I've run my headlights in manual mode for a long time (I usually don't drive after dark, but they are easy to flip up and down if I do).
When you do fix it, consider one of these electric conversion kits. Made in USA. Beware of cheap imitations.
https://www.ebay.com/itm/155261365162
Received 4,855 Likes
Cruise-In VIII Veteran
You really don't need to purchase a smoke machine. A vacuum guage works just fine.
Just take it in steps. Plug off the lines to the headlight relays. Connect vacuum guage to vacuum tank. Does it read the same as when hooked to the manifold? Shut off car, does it hold vacuum? Yes move towards testing the relays, no. Back up. Vacuum leak behind the dash? Plug off vacuum lines that head through the firewall. Hold vacuum now? No, test vacuum check valve.
Going the other way. Test relays to see if they hold vacuum. They don't? Repair. When they do, test actuators. Etc. Etc.
redman76 (05-18-2024)
I went electric and am very happy with it
