68-77 T-Top Center Panel & Rear Roof Panel Screws
Where do the 2 small black screws go that come in this set? Many thanks.
https://www.zip-corvette.com/68-77-t...el-screws.html
I'm about to get there on mine. I believe those black screws go into the panel front which are covered by the other moulding pieces. The chrome screws are used in the areas which are exposed.
Hmm, I think the front gets secured by the visor screws and windshield trim screws going all the way through. I was thinking they were used for the center back since it angles up there and is a little more shallow.
Went back to my AIM (73) and it shows the rear screws being the same as the others. Total of ten going into the side and center mouldings referenced as screw 3922441. There are two other screws, one into each side moulding listed as screw 9418962.
The two front screws 3893979 were described in an earlier forum post as a #8-3/8 black phillips head trim screw with a button head and flat underside. I haven't done my sun visors yet and know those screws are long small head chrome screws. Not sure if this helps but that's what I found.
