rear knock
Old May 20, 2024 | 01:16 PM
scott1959's Avatar
scott1959
Default rear knock
Have a 69' 427 with automatic transmission. Just took car out for first time in last 6 months. Noticed a knock in the rear area of car just about every time I let off the gas . Have any ideas as to the cause of this?
Thanks.
Old May 20, 2024 | 01:25 PM
Bikespace's Avatar
Bikespace
Mechanical? Differential snubber bushing?
In the exhaust? Afterfire from lean misfire?
Old May 20, 2024 | 02:04 PM
Tampa Jerry's Avatar
Tampa Jerry
If you think it's suspension related, check to see if the shims in frame pocket where the trailing arm connects to the frame. While there, check to see if the bushings are intact. Jerry
Old May 20, 2024 | 06:30 PM
SEVNT6's Avatar
SEVNT6
That's what it was for me...
Old May 20, 2024 | 07:05 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
U joints, snubber bushing, trailing arm bushing? We can all guess all day but maybe you should get under it and check it out!
Old May 21, 2024 | 07:32 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
check out the snubber and all of the associated bolts like has been suggested. THats exactly what they do
To rear knock
