Start help!
Old May 24, 2024 | 08:48 PM
am6174uh's Avatar
am6174uh
Default Start help!
Hey guys I need some help! My 69 350/350 L46 M20 4 speed car started up fine today and after getting gas I parked. 30 mins later, I came out to leave and the car won’t crank. Radio, battery and clock/ lights work. Checked the battery and starter. Both have power and I pulled the started and had it bench tested which was good also.
I did find a few connections under the dash disconnected (see photo). I’m not sure what else to do. Could the solenoid be bad? It’s getting power.
under the dash there was a pink wire disconnected, a 2 yellow wire disconnected and a 2 wire purple disconnected. Connected the yellow&purple but I’m not even sure that’s right. Any help is greatly appreciated.
car started, drove hot gas and started again no problem. Now nothing
Old May 24, 2024 | 10:39 PM
Eliredandblack's Avatar
Eliredandblack
Check the clutch safety switch, it’s under the dash. Use alligator clips and a piece of wire to jump it out. How old is your battery, with the headlights on, when you move the key to start does the headlights dim?
Old May 24, 2024 | 10:43 PM
am6174uh's Avatar
am6174uh
I’ll check the safety switch, I didn’t notice the lights dimming. I did notice the radio would cut out when I tried. Battery isn’t new. We tried to jump it and nothing
Old May 24, 2024 | 10:47 PM
Piersonpie's Avatar
Piersonpie
Threads like this come up about once a week, doing a quick search of “car won’t start” should give you quite a large number of results.
99% of the time if all other electronics work, but the car won’t otherwise start, it’s the negative battery cable coming out of the battery tray underneath the car and grounding to the frame.
Take the bolt out, clean up the frame to ensure you’re attaching to good metal, and reinstall.
There’s a debate whether dielectric grease should be used on the threads since it is an insulator. In my opinion the ability of the grease covering the metal, keeping it in an anaerobic environment and preventing future corrosion, greatly outweighs the fractions of an ohm increase of the connection. Especially considering this is such a common place for corrosion to occur.
Best of luck
Old May 24, 2024 | 10:49 PM
am6174uh's Avatar
am6174uh
99% of the time if all other electronics work, but the car won’t otherwise start, it’s the negative battery cable coming out of the battery tray underneath the car and attaching to the frame.
Best of luck
i have searched and tried a few things but I’ll definitely get into the terminal and check that! Thanks!
Old May 25, 2024 | 04:53 AM
Eliredandblack
Do the wires going to the starter look ok? Take a really close look and make sure they are ok. There are special “fusible link” wires (attached to the starter) that will melt if there is a short.
Old Jun 2, 2024 | 07:52 PM
Bikespace's Avatar
Bikespace
Thread continued by OP here:
https://www.corvetteforum.com/forums...ring-help.html
ICYMI
Old Jun 2, 2024 | 07:56 PM
am6174uh's Avatar
am6174uh
Originally Posted by Bikespace
thanks bikespace, not sure if I should have just keep this thread going?
Old Jun 2, 2024 | 08:04 PM
Bikespace's Avatar
Bikespace
If it's the same issue, it's helpful to those who have subscribed. They'll find it now.
To Start help!
