ZZ502 idle mix tuning
Old Apr 30, 2025 | 08:19 PM
  #101
jyounane's Avatar
jyounane
Thanks Leigh1322,
I actually have a TKO 600 5 speed with 0.82 5th gear ratio and 3.08 rear.
The speedometer is very accurate but not so sure about the tach. That said, I cruise at 70mph with an indicated 2300rpm give or take and around 2000rpm at 60mph.
It's very driveable in 5th and rarely need to go back to 4th above 45mph.
Joe
Old Apr 30, 2025 | 09:35 PM
  #102
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
That is good news!
My setup is the factory 3.36, but I have the .68 OD TKX. Mine top gear should be very similar to yours, just a couple less, 2000 @ 70 and 1730 @ 60 mph, 1500 @ 52+
But I do like the smaller and nice even gear drops your CR version has between the gears.
Mine is more like a 4sd with a bigger drop into OD for cruising.
Close enough either way with all that torque!
Enjoy the road trips!
Old Apr 30, 2025 | 11:43 PM
  #103
jyounane's Avatar
jyounane
Hi Leigh1322,
Hopefully you'll get better than 16 MPG.
On the long trips I have to stop for fuel at least every three hours. The guys with the newer vettes fill up every second stop!
Joe
Old May 1, 2025 | 05:35 AM
  #104
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I get 12 with my 5 speed and 4.11 gears. Mostly always on backroads. 15 or better is awesome and Im jealous
Old May 2, 2025 | 04:10 PM
  #105
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Looks like you have about 13.8 to 14.5 AFR @ 2000-2300, at your cruise speed.
And got 15.6 mpg there, on a long road trip.
I am going to shoot hard for 16 AFR @ a slightly lower 2000 rpm cruise.
The math says I could get 18mpg or even more.
I like a challenge.
I did find two reports of 454s getting 19 mpg, so I am hopeful!
Old May 2, 2025 | 07:16 PM
  #106
Rescue Rogers
I hope i can get more than 12 mpg
Old May 2, 2025 | 11:23 PM
  #107
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
With eight carbuerators??????
Old May 3, 2025 | 08:14 AM
  #108
Rescue Rogers
Well if each one gets 2 mpg then thats 16 mpg...right!!??
Old May 3, 2025 | 12:02 PM
  #109
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
